Home » Archived » BIRT » read from an xml data source problem
read from an xml data source problem [message #168286] Wed, 07 June 2006 16:08 Go to next message
Originally posted by: sinaizad.gmail.com
hi
i have a problem reading data from an xml file which is over the net on a remote machine(example: http://10clicksurveys.com/FILES/test.xml).
i was wondering if BIRT allows to read from a URL that is not local. if it does why am i getting an error that it cant be retrieved.
what i do is when i make a new data source i choose xml as a data source type and then it asks for the url. after that when i try to make a new data set it asks for an url again and when i enter the above url and click on next, it gives me an error that it cant rerieve data.
here is the detail of the error:
<i>An unexpected internal exception occurred.Please see log for detail.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Designer UI
Plug-in ID:org.eclipse.birt.report.designer.ui
Version:2.0.1
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:XML data source cannot be retrieved.XML data source file is invalid or the file doesn't exist.</i>
Re: read from an xml data source problem [message #168382 is a reply to message #168286] Wed, 07 June 2006 21:08 Go to previous messageGo to next message
Can you try any of the 2.1RC builds. This issue should have been resolved.
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"sina" <sinaizad@gmail.com> wrote in message
news:13053886.1149710938809.JavaMail.root@cp1.javalobby.org...
> hi
> Version:2.0.1
Re: read from an xml data source problem [message #168664 is a reply to message #168382] Thu, 08 June 2006 13:29 Go to previous messageGo to next message
hi there
thanx for your help, but...
i tried to install the RC4 build but it wont allow me since im using the eclipse 1.0.2 it requires eclipse 1.2. <b>currently im using BIRT Release Build 2.0.1 is this no good?!</b>. i was wondering if anyone else has the same problem!!
as i stated before my problem is accessing the data source which is an xml file on a remote machine.
<b>what we're trying to do here is to have an spring application generete an xml url and then use the same url in our report as the data base.</b>
do i need to have the report viewer installed before i can do this?(im new to this application and im in desperate need for help)
thanx a million
Re: read from an xml data source problem [message #168680 is a reply to message #168382] Thu, 08 June 2006 13:52 Go to previous messageGo to next message
hi there
i tried to install the RC4 build but it wont allow me since im using the eclipse 3.1.2 it requires eclipse 3.2. <b>currently im using BIRT Release Build 2.0.1 is this no good?!</b>. i was wondering if anyone else has the same problem!!
thanx a million
Re: read from an xml data source problem [message #168709 is a reply to message #168680] Thu, 08 June 2006 16:44 Go to previous messageGo to next message
Sina,
For reference your issue is the same as this bugzilla entry
https://bugs.eclipse.org/bugs/show_bug.cgi?id=124989
This was fixed after 2.0.1 was released.
regards,
Gary Xue
BIRT Committer
news:27648349.1149789163901.JavaMail.root@cp1.javalobby.org...
> hi there
same problem!!
> thanx a million
Re: read from an xml data source problem [message #168856 is a reply to message #168709] Fri, 09 June 2006 09:36 Go to previous message
thank you very much.
i tried the new version and it worked.
thanks again for great advice.
Previous Topic:Web App Servlet Filtering
Next Topic:Accessing Java Objects via Session
Current Time: Sat Nov 08 14:33:19 EST 2025
Powered by FUDForum. Page generated in 0.05264 seconds
