Home » Modeling » GMF (Graphical Modeling Framework) » Problem using XMI Resource type
Problem using XMI Resource type [message #168202] Tue, 15 January 2008 07:07 Go to next message
Originally posted by: zzhangh.cn.ibm.com
I have generated a GMF application, after that I changed GenPackage
element in .genmodel to use "XMI" as Resource Type, and overrode
MyResourceImpl#useUUIDs() to return true, so that EMF will automatically
generate an ID for every object in my model.
The problem is I can't create any visual element in diagram editor, the
editor reports "Invalid view - remove from diagram." every time I tried
to drop a node, even after I re-generated the .gmfgen and the code.
Is there anything I need to specify in gmfgen?
Hao
Re: Problem using XMI Resource type [message #168211 is a reply to message #168202] Tue, 15 January 2008 07:18 Go to previous messageGo to next message
Hao,
Note that for EMF's generator the plugin.xml is not regenerated once it
exists so it's likely that your specialized resource type has not been
properly registered for your model in the plugin.xml for the model. Try
removing the MANIFEST.MF and plugin.xml of your model project and
regenerating the model again to regenerate these two artifacts. There
might be other issues, but this seems a likely one...
Hao Zhang wrote:
> Hao
Re: Problem using XMI Resource type [message #168529 is a reply to message #168211] Wed, 16 January 2008 21:05 Go to previous messageGo to next message
Hi Ed:
I've already removed the two files and I'm quite sure they are
re-generated, here is content of plugin.xml:
<plugin>
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri = "http://erm"
class = "com.my.erm.ErmPackage"
genModel = "model/erm.genmodel" />
</extension>
<extension point="org.eclipse.emf.ecore.extension_parser">
<parser
type="erm"
class="com.my.erm.util.ErmResourceFactoryImpl" />
</extension>
</plugin>
After changing to use XMI resource type, EMF generated editor works well
but GMF diagram editor not, so I'm guessing maybe I have something to be
done at GMF part?
Hao
Ed Merks Wrote:
> Hao,
> Hao Zhang wrote:
>> Regards,
>> Hao
Re: Problem using XMI Resource type [message #168583 is a reply to message #168529] Thu, 17 January 2008 05:13 Go to previous messageGo to next message
Hao,
I guess so, but I don't know about that part. Is your instance data
being stored in a file with "*.erm" extension when you are using the GMF
editor to edit the instance?
Hao Zhang wrote:
> Hi Ed:
> <plugin>
> <package
> uri = "http://erm"
> </extension>
> <parser
> type="erm"
> </extension>
> </plugin>
> done at GMF part?
> Hao
> Ed Merks Wrote:
>> Hao,
>> Hao Zhang wrote:
>>> Hi,
>>> Regards,
>>> Hao
Re: Problem using XMI Resource type [message #168879 is a reply to message #168583] Sun, 20 January 2008 21:17 Go to previous message
Exactly.
Ed Merks wrote:
> Hao,
> Hao Zhang wrote:
>> Hi Ed:
>> <plugin>
>> <package
>> uri = "http://erm"
>> </extension>
>> <parser
>> type="erm"
>> </extension>
>> </plugin>
>> done at GMF part?
>> Regards,
>> Hao
>> Ed Merks Wrote:
>>> Hao,
>>> Hao Zhang wrote:
>>>> Hi,
>>>> Regards,
>>>> Hao
Previous Topic:Example for 2.1M4
Next Topic:How to display semantic data multiple times on the same diagramm
Current Time: Tue Nov 11 14:08:42 EST 2025
Powered by FUDForum. Page generated in 0.03565 seconds
