Home » Language IDEs » Java Development Tools (JDT) » How to compile in foreground ?
How to compile in foreground ? [message #167870] Fri, 09 July 2004 01:33 Go to next message
Originally posted by: somewhere.nowhere.com
I recently migrated to Eclipse 3.0 M8 (Build id: 200403261517).
Some observations:
1. Project Building/ compiling happens in a scheduled manner.
How to disable that? I prefer the compilation with a blocking dialog as
in Eclipse 2.x
2. The Sychronise view shows the items in a "Flat" view as opposed to
"Heirarchial" which was so in Eclipse 2.x. The "Heirarchial" looks better
so that there is less repeated-text, how to enable that? (The Package
explorer view has the provision, why not 'synchronize' view)
thks
g1
Re: How to compile in foreground ? [message #167904 is a reply to message #167870] Fri, 09 July 2004 06:23 Go to previous messageGo to next message
Jeevan-S wrote:
> Some observations:
> in Eclipse 2.x
> thks
> g1
Why don't you use Eclipse 3.0 final?.
Re: How to compile in foreground ? [message #167910 is a reply to message #167904] Fri, 09 July 2004 07:59 Go to previous messageGo to next message
David,
Can u elaborate pls?
What do u mean final?
(i downloaded eclipse-SDK-3.0M8-win32.zip 89,942Kb) from the eclipse main
download site.
thks
g1
> Jeevan-S wrote:
> > Hi,
> > Some observations:
> > in Eclipse 2.x
> > thks
> > g1
Re: How to compile in foreground ? [message #167926 is a reply to message #167910] Fri, 09 July 2004 08:29 Go to previous messageGo to next message
Jeevan-S wrote:
> David,
> download site.
Eclipse 3.0Mx versions of eclipse are milestone version.
Milestone versions are incomplete/development verion that lead the path
to the final version, the 3.0 version, which is out since June 28th.
( http://download.eclipse.org/downloads/drops/R-3.0-2004062512 08/index.php
on the main download site)
> thks
> g1
>>Jeevan-S wrote:
>>>Hi,
>>>Some observations:
>>> in Eclipse 2.x
>>>thks
>>>g1
Re: How to compile in foreground ? [message #167962 is a reply to message #167870] Fri, 09 July 2004 11:05 Go to previous message
Originally posted by: eclipse.rizzoweb.com
Jeevan-S wrote:
As others have recommended - go get the 3.0 Release version.
In your Synchronize view, click the "options" button (black down-arrow
in the upper right corner of the view) - there you can select the Layout
you want, including a Hierarchical one.
HTH,
Eric
Previous Topic:Running JUnit tests held in multiple projects
Next Topic:Unwanted persistant hover
Current Time: Fri Jul 18 00:45:21 EDT 2025
Powered by FUDForum. Page generated in 0.08206 seconds
