Home » Language IDEs » C / C++ IDE (CDT) » Problem with New C++ Class wizard
Problem with New C++ Class wizard [message #167738] Mon, 10 April 2006 06:14 Go to next message
Hi!
I meet some problems defining new classes using the CDT wizard
(New->C++->Class). When I
want to select an existing class as a base class Eclipse tells me "No
class available!" (allthough
it's there!!)
I'm running Eclipse 3.1.1 + CDT 3.0.2 on Win XP with cygwin.
Does anybody knows something about this problem????
My log-File tells me the following message:
!ENTRY org.eclipse.ui 4 0 2006-04-10 12:01:52.606
!MESSAGE Widget is disposed
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.SWT.error(SWT.java:2836)
at org.eclipse.swt.widgets.Widget.error(Widget.java:395)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:297)
at org.eclipse.swt.widgets.Control.setEnabled(Control.java:2092 )
org.eclipse.jface.wizard.WizardDialog.restoreEnableState(Wiz ardDialog.java:792)
org.eclipse.jface.wizard.WizardDialog.restoreUIState(WizardD ialog.java:807)
at org.eclipse.jface.wizard.WizardDialog.stopped(WizardDialog.j ava:1077)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 837)
org.eclipse.update.internal.ui.wizards.ReplaceFeatureVersion WizardPage.swap(ReplaceFeatureVersionWizardPage.java:162)
org.eclipse.update.internal.ui.wizards.ReplaceFeatureVersion WizardPage.performFinish(ReplaceFeatureVersionWizardPage.jav a:129)
org.eclipse.update.internal.ui.wizards.ReplaceFeatureVersion Wizard.performFinish(ReplaceFeatureVersionWizard.java:33)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.update.internal.ui.views.ReplaceVersionAction.ru n(ReplaceVersionAction.java:56)
org.eclipse.update.internal.ui.views.ConfigurationView$Previ ewTask.run(ConfigurationView.java:342)
org.eclipse.update.internal.ui.views.ConfigurationPreview$2. linkActivated(ConfigurationPreview.java:78)
at org.eclipse.ui.forms.widgets.FormText.activateLink(FormText. java:1466)
org.eclipse.ui.forms.widgets.FormText.handleMouseClick(FormT ext.java:1281)
at org.eclipse.ui.forms.widgets.FormText.access$19(FormText.jav a:1255)
at org.eclipse.ui.forms.widgets.FormText$6.mouseUp(FormText.jav a:387)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:137)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Erstellt mit Opera
Re: Problem with New C++ Class wizard [message #167755 is a reply to message #167738] Mon, 10 April 2006 07:24 Go to previous message
Sorry, I made one mistake, the error message seems to be caused by another
problem.
But the problem still exists, but without any additional error message.
Can anybody help?
Andrés
Andrés <ponch@gmx.de> wrote on 10.04.2006, 12:14 Uhr:
> Hi!
> it's there!!)
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Erstellt mit Opera
Previous Topic:C in WinXP
Next Topic:odbc database script written in C and I am trying to get script to run in eclips
Current Time: Fri Nov 07 09:02:30 EST 2025
Powered by FUDForum. Page generated in 0.03210 seconds
