Home » Language IDEs » Java Development Tools (JDT) » Errors in Exporting Plugins - could anyone explain why?
Errors in Exporting Plugins - could anyone explain why? [message #167694] Thu, 08 July 2004 09:47 Go to next message
Originally posted by: phil.dadabeatnik.com
Hi there,
Im trying to Export two plugin projects at the same time using the Export
wizard in Eclipse 3.0 on Windows, Sun 1.1.4 JVM. When I Export them one at
a time there is not a problem, but if I select both together in the Export
dialog window and then Export there is produced a zip with errors such as
this:
1. ERROR in
D:\projekts\workspace\reload-jdom-plugin\src\uk\ac\reload\jd om\XMLActiveDocu
ment.java (at line 49)
import org.jdom.Document;
The import org.jdom cannot be resolved
I have one simple project which basically wraps a jdom.jar as a plugin like
this
<plugin
id="org.jdom.plugin"
name="JDOM Plug-in"
version="0.9.0"
provider-name="Reload Tools">
<runtime>
<library name="jdom.jar">
<export name="*"/>
</library>
</runtime>
</plugin>
And then I have another Java Plugin Project that depends on the first one:
<plugin
id="uk.ac.reload.jdom.plugin"
name="Reload_jdom_plugin Plug-in"
version="1.0.0"
provider-name=""
class="reload_jdom_plugin.Reload_jdom_pluginPlugin">
<runtime>
<library name="reload_jdom_plugin.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="org.jdom.plugin"/>
</requires>
</plugin>
Any help appreciated!
Phillipus
Re: Errors in Exporting Plugins - could anyone explain why? [message #167748 is a reply to message #167694] Thu, 08 July 2004 10:33 Go to previous message
OK, a quick search of Bugzilla reveals this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=68712
Phillipus
"Phillipus" <phil@dadabeatnik.com> wrote in message
news:ccjj6s$if1$1@eclipse.org...
> Hi there,
> this:
> 1. ERROR in
like
> this
> <plugin
> name="JDOM Plug-in"
> version="0.9.0"
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
> </plugin>
> <plugin
> version="1.0.0"
> provider-name=""
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
> <requires>
> </requires>
> </plugin>
> Phillipus
Previous Topic:Many projects based on one source directory
Next Topic:Compilation errors in Tasks in 3.0
Current Time: Sun Aug 31 22:18:17 EDT 2025
Powered by FUDForum. Page generated in 0.03150 seconds
