Home » Language IDEs » ServerTools (WTP) » project dpendency
project dpendency [message #167584] Wed, 26 April 2006 02:02 Go to next message
Why is adding a project dependency for a WTP project (J2EE Module
Dependencies) different than for a normal java project (Build Path ->
Projects)?
Re: project dpendency [message #167608 is a reply to message #167584] Wed, 26 April 2006 08:14 Go to previous messageGo to next message
Java development in Eclipse is supported by JDT. JDT knows how to run
Java applications. However, Web application != Java application. Web
applications are "hosted" in a servlet container, which JDT currently
knows little if anything about. Therefore, changing JDT's build path
only affects building. To add a JAR to the build path and have it
available to the Web application at runtime, you have to use J2EE Module
Dependencies. The "J2EE" implies it knows how to handle Web applications.
Note that if the servlet container supplies classes or JARs that don't
appear in the Dynamic Web Project's target runtime, such as having JARs
in Tomcat's "shared/lib", you would want to only modify the build path.
It would be nice if when you add a JAR to the build path, something
could ask or allow you to indicate if it should also go into the Web
application's WEB-INF/lib. I'm not sure if the APIs in JDT are
currently sufficient to allow this to be implemented in a way the Web
Tools can build upon. Maybe someday.
Larry
Zohar wrote:
> Hello,
> Projects)?
Re: project dpendency [message #167617 is a reply to message #167608] Wed, 26 April 2006 08:41 Go to previous messageGo to next message
Thank you. Great answers as always.
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:e2no84$jj2$1@utils.eclipse.org...
> knows little if anything about. Therefore, changing JDT's build path only
> affects building. To add a JAR to the build path and have it available to
> the Web application at runtime, you have to use J2EE Module Dependencies.
> appear in the Dynamic Web Project's target runtime, such as having JARs in
> It would be nice if when you add a JAR to the build path, something could
> application's WEB-INF/lib. I'm not sure if the APIs in JDT are currently
> sufficient to allow this to be implemented in a way the Web Tools can
> Cheers,
> Larry
> Zohar wrote:
>> Hello,
>> Projects)?
Re: project dpendency [message #168473 is a reply to message #167608] Thu, 04 May 2006 02:51 Go to previous messageGo to next message
What if my web module (WM) depends on a java project (JP1), which depends on
another java project (JP2)? When exporting to WAR, do I get JP1's classes
and JP2's classes in my WEB-INF/lib dir?
> Cheers,
> Larry
> Zohar wrote:
>> Hello,
>> Projects)?
Re: project dpendency [message #168495 is a reply to message #168473] Thu, 04 May 2006 09:18 Go to previous messageGo to next message
If JP1 has a build time dependency, then that dependency has to be
accounted for in WM at runtime. If the build time dependency is
something that will be made available at runtime by default, then WM
doesn't need to change. In your example, it seems likely that this
won't be the case. Thus, to address the runtime dependency, you will
need to add JP2 to the J2EE Module Dependencies of WM so both will be
added to WEB-INF/lib as JARs.
Note that currently, the JARs created in this fashion include all of the
contents of the utility project, including Java source. I'll have to see
what might be done to improve this. If it matters, you may want to use
File -> "Export..." -> "JAR file" to create "official" versions of these
JARs before deploying to a production site.
Larry
>> Cheers,
>> Larry
>> Zohar wrote:
>>> Hello,
>>> Projects)?
Re: project dpendency [message #168535 is a reply to message #168495] Thu, 04 May 2006 13:00 Go to previous message
I need to correct the statement below about the utility JARs being
created with all of the project's contents. I see this when I'm running
debug sessions in my build environment, i.e. I have an Eclipse with WTP
source checked out into my workspace and I'm running a debug session of
Eclipse+WTP using this source.. I'm not seeing this behavior with
installed versions of WTP, where just the class files are included.
While I don't have an explanation for the difference, I have seen other
differences between debugging sessions and installed sessions. I'll
have to remember to check such things when uncovered in a debug session.
Sorry if I alarmed anybody.
Larry
> Cheers,
> Larry
>> depends on another java project (JP2)? When exporting to WAR, do I get
>> JP1's classes and JP2's classes in my WEB-INF/lib dir?
>>> run Java applications. However, Web application != Java
>>> application. Web applications are "hosted" in a servlet container,
>>> which JDT currently knows little if anything about. Therefore,
>>> changing JDT's build path only affects building. To add a JAR to the
>>> build path and have it available to the Web application at runtime,
>>> you have to use J2EE Module Dependencies. The "J2EE" implies it knows
>>> don't appear in the Dynamic Web Project's target runtime, such as
>>> having JARs in Tomcat's "shared/lib", you would want to only modify
>>> the build path.
>>> Cheers,
>>> Larry
>>> Zohar wrote:
>>>> Hello,
>>>> -> Projects)?
Previous Topic:Web project can't see .jar in dependent project
Next Topic:jBoss org.xml.sax.SAXException: No deserializer for [...]
Current Time: Tue Nov 25 17:07:48 EST 2025
Powered by FUDForum. Page generated in 0.16680 seconds
