Home » Language IDEs » C / C++ IDE (CDT) » Run External Tool w/o Build before launch
Run External Tool w/o Build before launch [message #167572] Fri, 07 April 2006 02:40 Go to next message
I have defined an External Tool that will create my Makefiles. Now every
time I run it all my projects get rebuild (if source code was modified)
because I have activated
Preferences->Run/Debug->Launchung->Build before launching
This is especially nasty when I have updated my source code via CVS and
rebuild my Makefiles (first all projects are rebuild, then the new
Makefiles are created and then I have to rebuild all projects again).
Of course, I can deactivate "Build before launching" but I need this
option for my debug sessions.
The only workaround seems to deactivate "Build before launching", launch
my external tool and then reactivate "Build before launching". Is it
possible to deactivate "Build before launching" only for External Tools?
Re: Run External Tool w/o Build before launch [message #167589 is a reply to message #167572] Fri, 07 April 2006 03:02 Go to previous messageGo to next message
You can register your external tool as an additional builder in the
Project Properties. You should make sure that it is listed before the
CDT builder so that the Makefiles get generated before make is launched.
HTH,
Toni
> option for my debug sessions. The only workaround seems to deactivate
> "Build before launching", launch my external tool and then reactivate
> "Build before launching". Is it possible to deactivate "Build before
Re: Run External Tool w/o Build before launch [message #167604 is a reply to message #167589] Fri, 07 April 2006 03:53 Go to previous messageGo to next message
But if I have several projects open the External Builder will be launched
for every project and every time I changed my sources.
Re: Run External Tool w/o Build before launch [message #167762 is a reply to message #167604] Mon, 10 April 2006 09:31 Go to previous messageGo to next message
Originally posted by: arne.anka.ginguppin.de
quote: "in the Project Properties."
> launched for every project and every time I changed my sources.
Re: Run External Tool w/o Build before launch [message #168386 is a reply to message #167762] Wed, 19 April 2006 02:15 Go to previous message
I guess my message was a little bit misunderstanding. We have one single
script that creates the Makefiles for all our projects. I run this script
manually as an external program. If I add it as an additional builder then
all Makefiles will be recreated for every project I build. That's not what
I want.
Previous Topic:CPU is not supported by selected debugger
Next Topic:Working Set from Project References
Current Time: Sat Nov 08 11:44:47 EST 2025
Powered by FUDForum. Page generated in 0.03192 seconds
