project selection, search for main method [message #167307] |
Mon, 05 July 2004 17:13 |
Originally posted by: sn.srv.ca
Hello.
Eclipse 3.0, using j2sdk1.4.2_04, under W2K, searches the
JRE System Library for main methods. This happens when the
project is selected, and then
Run As ... --> Java Application
is clicked. How do I prevent Eclipse from looking for main
methods in the JRE System Library?
I am aware that I can select the class or package, or create
my own Launch Configuration. Yet, as in Eclipse 2.1.3, it's
less confusing for novice users to also run code by choosing
the project.
Note that
-- Eclipse 2.1.3 in W2K does not search the
JRE System Library when using j2sdk1.4.2_04 or
jdk1.3.1_11.
-- When I say "using j2sdk1.4.2_04", I mean that
Eclipse runs using that JRE and SDK, plus projects
are compiled and executed using that JRE and SDK.
Cheers
Stef Nychka, Lab Instructor
Department of Computing Science
University of Alberta
FUDForum. Page generated in 0.25805 seconds
