Home » Archived » BIRT » how to make an element fit the hole page
how to make an element fit the hole page [message #167271] Sat, 03 June 2006 06:22 Go to next message
Originally posted by: wohlgemuth.ucdavis.edu
hi I have a short question
i need to generate a couple of pdf reports.
the idea is every side has 1 graph and the graph has to be rendered that he
fills the side.
the output format is pdf.
the initial idea was to say height = 100%
- dont work
another idea was to specify the size manually
- dont work
so how can i solve this problem.
it can't be so hard to create on chart a side as pdf output. And the chart
takes all space up and not only 5 x 5 cm...
thx in advance,
gert
Re: how to make an element fit the hole page [message #167331 is a reply to message #167271] Sun, 04 June 2006 23:15 Go to previous messageGo to next message
i played a little more with this and it looks like
there is a bug in birt
1. if i specify 100% use of available space, I think it should fill the page
to 100% usable space
2. if i say 5 inch heigh, it will be 5 in in html, but only 2 or so in pdf.
any ideads? This happens only with graphs...
"gert wohlgemuth" <wohlgemuth@ucdavis.edu> wrote in message
news:e5rnsn$kdf$1@utils.eclipse.org...
> he fills the side.
> - dont work
> - dont work
> thx in advance,
> gert
Re: how to make an element fit the hole page [message #167449 is a reply to message #167331] Mon, 05 June 2006 10:24 Go to previous message
ok the RC4 does the job,
sweet just lost 3 days...
news:e607l9$9q3$1@utils.eclipse.org...
> page to 100% usable space
> pdf.
>> he fills the side.
>> - dont work
>> - dont work
>> chart takes all space up and not only 5 x 5 cm...
>> thx in advance,
>> gert
Previous Topic:out of memory exception
Next Topic:BIRT VIEWER PARAMETERS
Current Time: Thu Nov 20 17:09:30 EST 2025
Powered by FUDForum. Page generated in 0.03315 seconds
