| Aligning multiline columns in table (PDF) [message #167127] |
Fri, 02 June 2006 14:14 |
Hi.
I am using Birt 2.1RC3a and I noticed that multiline text in table columns
are not aligned properly when Previewing or generating report into PDF. In
designer I select cell and set Text alignment to Centered and also on Label
in that cell I set alignment to Center. This problem is not specific to
Label since the same problem is with Text component.
Anybody knows if this is a known bug and is there a workaround to adjust
alignment of text in cells?
I attached a simple report with sample table with all aligning properties
set which looks OK in designer but in PDF text in cells are unaligned?
B
FUDForum. Page generated in 0.03923 seconds
