Home » Language IDEs » Java Development Tools (JDT) » Eclipse 3: "!CompileErrorPromptStatusHandler.1!"
Eclipse 3: "!CompileErrorPromptStatusHandler.1!" [message #166756] Thu, 01 July 2004 06:51 Go to next message
Originally posted by: mb.thomas-daily.de
Hi there!
I just switched from Eclipse 2.1.x to 3.0 final (Win XP).
I copied the whole "workspace" into new eclipse -- is that right?
Starting programs inside Eclipse a dialog window pops with the
message "!CompileErrorPromptStatusHandler.1". What does this mean?
thanx!
Marcus
Re: Eclipse 3: "!CompileErrorPromptStatusHandler.1!" [message #166764 is a reply to message #166756] Thu, 01 July 2004 09:11 Go to previous messageGo to next message
Hi, Marcus
Marcus Beyer wrote:
> Hi there!
No, it is not, workspaces contain information that is specific to a
given version of eclipse.
I is strongly recommended to create a new workspace for each version of
eclipse that you install and import projects from older workspaces with
the Import feature.
All sorts of incomprehensible errors might popup by taking a workspace
from an eclipse version to an other.
> thanx!
> Marcus
Hope this helps.
Re: Eclipse 3: "!CompileErrorPromptStatusHandler.1!" [message #166864 is a reply to message #166764] Thu, 01 July 2004 13:41 Go to previous messageGo to next message
> the Import feature.
So I have to delete ".metadata" and do File/Import "Existing Project
into Workspace"?
Hmm, I did as described but have still the same problem :(
any ideas?
Marcus
Re: Eclipse 3: "!CompileErrorPromptStatusHandler.1!" [message #166872 is a reply to message #166764] Thu, 01 July 2004 15:49 Go to previous messageGo to next message
Using a 2.1 workspace with 3.0 should work fine.
back the other way is not supported.
johan
Jean Couillaud wrote:
> Hi, Marcus
> Marcus Beyer wrote:
>> Hi there!
> the Import feature.
>> thanx!
>> Marcus
> Hope this helps.
Re: Eclipse 3: "!CompileErrorPromptStatusHandler.1!" [message #166945 is a reply to message #166756] Fri, 02 July 2004 06:43 Go to previous message
Marcus Beyer schrieb:
> Hi there!
I just found out that a plugin (MyEclipse) is causing the problem.
thanx!
Marcus
Previous Topic:JDI Bootstrap throws Errors
Next Topic:Use of Tomcat Plugin for Servlet Execution?
Current Time: Thu Jul 17 20:35:46 EDT 2025
Powered by FUDForum. Page generated in 0.28726 seconds
