Home » Newcomers » Newcomers » 3.2 does not convert source file encoding
3.2 does not convert source file encoding [message #166595] Tue, 22 August 2006 03:55 Go to next message
Eclipse 3.1 did some magic with the source file encoding so files were
encoded in ISO-8859-1, but local characters of Polish language were still
available and dispayed properly in program.
Eclipse 3.2 does not it only displays "File cant be saved in
ISO-8859-1/**/" message, and asks me to remove all unsupported characters
- but I like very much my unsupported characters! Is there a way to enable
3.1 like behaviour? Because if not I think it's a bug.
Re: 3.2 does not convert source file encoding [message #166603 is a reply to message #166595] Tue, 22 August 2006 04:33 Go to previous messageGo to next message
> still available and dispayed properly in program. Eclipse 3.2 does not
> it only displays "File cant be saved in ISO-8859-1/**/" message, and
That's the only correct behavior because previously some of those
unsupported characters might have gotten lost on save i.e. you lost work.
> enable 3.1 like behaviour?
You can of course change the encoding for the file, folder or all
*.properties files to some other encoding but it means that your Strings
might show up corrupted when running because the Java VM will use
ISO-8859-1 to read them in. You should not do this - instead encode your
local characters correctly in the properties file, read
http://java.sun.com/j2se/1.4.2/docs/api/java/util/Properties .html#encoding
for more info.
It is not a bug - it was one before (see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=116841).
Dani
Re: 3.2 does not convert source file encoding [message #166609 is a reply to message #166603] Tue, 22 August 2006 05:40 Go to previous message
OK. I understand that smarter people than me said it is dangerous. But no
such thing happened to me.
> for more info.
Well I didn't get the hint.. Are you sure that this is a proper link? Word
encoding in that file occurs only three times and only to suggest to use
ISO encoding or native2ascii. Is there any way to have polish chars in
Java program, that doesn't require either calling native2ascii on every,
or manually adding these hideous escape chars?
Previous Topic:File Saerch via API
Next Topic:Eclipse 3.2 installation problem on OS X Tiger
Current Time: Sat Sep 06 09:50:30 EDT 2025
Powered by FUDForum. Page generated in 0.34685 seconds
