Home » Eclipse Projects » Nebula » Resizing GridEditor redraw issues
Resizing GridEditor redraw issues [message #15697] Fri, 27 October 2006 10:27 Go to next message
Trying to code up a Grid with an GridEditor using a Text Widget.
But I'm running into redraw problems, as the Text widget flickers over the
the GridColumn header as the shell gets resized.
Below is the code I'm using.
Is there anything I'm doing wrong??
Grid grid = new Grid(shell,SWT.BORDER | SWT.V_SCROLL | SWT.H_SCROLL);
grid.setHeaderVisible(true);
GridColumn column = new GridColumn(grid,SWT.NONE);
column.setText("Name");
column.setWidth(300);
GridItem item1 = new GridItem(grid,SWT.NONE);
Text text = new Text(grid, SWT.NONE);
text.setText("my Item");
item1.setText(text.getText());
GridEditor editor = new GridEditor(grid);
editor.setEditor(text, item1, 0);
editor.grabHorizontal = true;
Re: Resizing GridEditor redraw issues [message #15718 is a reply to message #15697] Fri, 27 October 2006 12:51 Go to previous messageGo to next message
Hi Asim,
What you're seeing is a result of a issue in SWT thats since been fixed.
See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=105764
I'm assuming you're running Eclipse 3.2. The bug has been fixed in 3.3
and I need to make some follow up changes in GridEditor.
Are you running 3.3?
-Chris
Re: Resizing GridEditor redraw issues [message #16142 is a reply to message #15718] Mon, 30 October 2006 06:18 Go to previous messageGo to next message
Hi Chris
Just tried it with Eclipse3.3M2 and encountered the same redraw glitches.
This was using jdk1.5.0_08.
Playing around, I commented out the line "editor.grabHorizontal = true;"
and redraw works without a problem, but the editor functionality seems
to be disabled.
(Are there any snippets that include GridEditor ?)
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.nebula.widgets.grid.Grid;
import org.eclipse.swt.nebula.widgets.grid.GridColumn;
import org.eclipse.swt.nebula.widgets.grid.GridEditor;
import org.eclipse.swt.nebula.widgets.grid.GridItem;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class GridTest
public static void main(String[] args)
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout(new FillLayout());
SWT.H_SCROLL);
//editor.grabHorizontal = true;
shell.setSize(250,250);
shell.open ();
while (!shell.isDisposed()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
"Chris Gross" <chris.gross@us.ibm.com> wrote in message
news:ehtdf0$8cl$1@utils.eclipse.org...
> Hi Asim,
> See:
Re: Resizing GridEditor redraw issues [message #16169 is a reply to message #16142] Tue, 31 October 2006 16:08 Go to previous message
3.3 M2 was released on Sept 22. The bug was fixed on Oct 10.....
Asim wrote:
> Hi Chris
> to be disabled.
> import org.eclipse.swt.widgets.Display;
> SWT.H_SCROLL);
> shell.open ();
> display.dispose ();
>> Hi Asim,
>> See:
Re: Resizing GridEditor redraw issues [message #567731 is a reply to message #15697] Fri, 27 October 2006 12:51 Go to previous message
Hi Asim,
See:
-Chris
Re: Resizing GridEditor redraw issues [message #567828 is a reply to message #15718] Mon, 30 October 2006 06:18 Go to previous message
Hi Chris
to be disabled.
SWT.H_SCROLL);
shell.open ();
display.dispose ();
> Hi Asim,
> See:
Re: Resizing GridEditor redraw issues [message #567888 is a reply to message #16142] Tue, 31 October 2006 16:08 Go to previous message
Asim wrote:
> Hi Chris
> to be disabled.
> SWT.H_SCROLL);
> shell.open ();
> display.dispose ();
>> Hi Asim,
>> See:
Previous Topic:CTableTree display
Next Topic:Picture gallery widget
Current Time: Fri Oct 24 06:28:07 EDT 2025
Powered by FUDForum. Page generated in 0.04897 seconds
