| Re: How to set color of selected member in code completion dialog. [message #166440 is a reply to message #166010] |
Wed, 30 June 2004 00:08  |
John Zoetebier wrote:
> Code completion (Ctrl+space) show a list of members of an object.
> It seems like the color scheme in Eclipse 30 has changed.
> Somehow I do not see the selected member anymore, for example when I click
> on a member I cannot see which member I selected.
> is there a way I can change the color of a selected member ?
From gmane.linux.mandrake.newbie news group:
> What you have to do is to go to Windows > Preferences > Java > Editor
> > Code Assist and the "Completion proposal foreground" to something
> other then black, something that contrasts with black but is still
> visible and then the line you select will have a black foreground
> while all the others will have your selected color. I am still
> looking for a better way to do it though and any hints from other
> users will be much appreciated.
> I am now installing the gnome control center (into KDE :-) to see if
> it can control the GTK colors.
Installing the gnome control center was indeed the solution. Using it,
I changed the GTK theme which fixed the problem we were having. Be
aware though that installing the gnome-control-center will cause many
other packages to be installed as well.
John Zoetebier
web site: http://www.transparent.co.nz
FUDForum. Page generated in 0.03788 seconds
