| TreeRouter Problem [message #165868] |
Wed, 19 December 2007 05:52   |
Eclipse User  |
--------------010405080004020208070909
i would like to use treeConnection in my diagrams.
If everything works when my connection is drawn directly in the canvas,
it is not the case inside another figure (a package for example).
It seems it is the TreeRouter and especially the trunkLocation point
that causes problems.
Is anybody had this problem ?
Content-Type: text/x-vcard; charset=utf-8;
 name="stephane_bouchet.vcf"
Content-Disposition: attachment;
 filename="stephane_bouchet.vcf"
begin:vcard
fn;quoted-printable:St=C3=A9phane Bouchet
n;quoted-printable:Bouchet;St=C3=A9phane
org:Obeo
adr;quoted-printable:;;;Rez=C3=A9;;44400;France
email;internet:stephane.bouchet@obeo.fr
x-mozilla-html:FALSE
version:2.1
end:vcard
--------------010405080004020208070909--
| Re: TreeRouter Problem [message #166081 is a reply to message #165967] |
Thu, 20 December 2007 05:30   |
Eclipse User  |
--------------000808060701090700050307
I finally found a solution :
in BranchRouter Class, in getTrunkLocation(...) method, i modified the
following line :
Point ptTrunkLoc = getTree().getTrunkLocation(conn); // default;
by :
Point ptTrunkLoc = conn.getTargetAnchor().getReferencePoint();
		conn.translateToRelative(ptTrunkLoc);
		Point translated = getTree().getTrunkOrientation().getEdge(
				conn.getTargetAnchor().getOwner().getBounds());
		boolean bTopDown = getTree().isTopDown(conn);
		if (bTopDown) {
			ptTrunkLoc = ptTrunkLoc.getTranslated(0, translated.y / 2);
		}else {
			ptTrunkLoc = ptTrunkLoc.getTranslated(0, -(translated.y / 2));
and now it is working..
Cheers !
St
FUDForum. Page generated in 0.58852 seconds
