Home » Modeling » GMF (Graphical Modeling Framework) » How to generate the diagram of the subpackages in a metamodel desribed in ecore?
How to generate the diagram of the subpackages in a metamodel desribed in ecore? [message #165477] Fri, 14 December 2007 11:25 Go to next message
As we know, we can right click an ecore model in the navigator of
eclipse to generate the diagram file for this model. Open this diagram file,
then we can visulize the model. However, only the classes in the topmost
packages will be drawn on the diagram. I also hope to visulize the classes
in the sub-packages. I don't know how to do it.
Thanks for your hint.
Michael.
Re: How to generate the diagram of the subpackages in a metamodel desribed in ecore? [message #165605 is a reply to message #165477] Mon, 17 December 2007 06:02 Go to previous messageGo to next message
Michael,
Do you want to visualize all of them on the same diagram ?
- If yes, you can try to DND the expected class from the Project
Explorer view.
- If no, you can probably double click on the Package you want to go
into : this will create a new diagram and will populate with the
EClasses that are contained inside.
A little advertisement ... Do you know the Ecore Tools project ? Feel
free to use try it and give us your feedback about missing features that
you would expect ! ;-)
Jacques
Michael a écrit :
> Michael.
Re: How to generate the diagram of the subpackages in a metamodel desribed in ecore? [message #165660 is a reply to message #165605] Mon, 17 December 2007 10:42 Go to previous messageGo to next message
Hi Jacques:
Thanks for your help. I have no idea of Ecore Tools project. Anyway, I
will try it and give you some feedback.
However, would you please tell me what DND stands for?
Thanks.
Michael.
"Jacques LESCOT" <jacques.lescot@anyware-tech.com> wrote in message
news:fk5kv3$5fs$1@build.eclipse.org...
> Michael,
> - If yes, you can try to DND the expected class from the Project Explorer
> view.
> - If no, you can probably double click on the Package you want to go into
> : this will create a new diagram and will populate with the EClasses that
> A little advertisement ... Do you know the Ecore Tools project ? Feel free
> to use try it and give us your feedback about missing features that you
> would expect ! ;-)
> Jacques
> Michael a
Re: How to generate the diagram of the subpackages in a metamodel desribed in ecore? [message #165683 is a reply to message #165660] Mon, 17 December 2007 11:15 Go to previous message
Sorry, DND for Drag and Drop.
Michael a écrit :
> Hi Jacques:
> Thanks.
> Michael.
>> Michael,
>> view.
>> would expect ! ;-)
>> Regards,
>> Jacques
>> Michael a écrit :
>>> Hi,
>>> file, then we can visulize the model. However, only the classes in the
>>> topmost packages will be drawn on the diagram. I also hope to visulize
>>> the classes in the sub-packages. I don't know how to do it.
>>> Michael.
Previous Topic:Editor background image and zooming performance problem
Next Topic:Compartment
Current Time: Sun Aug 31 16:22:09 EDT 2025
Powered by FUDForum. Page generated in 0.08677 seconds
