Cygwin Path [message #165400] |
Tue, 07 March 2006 23:45  |
Originally posted by: dqn.email.arizona.edu
I've been looking around, but havn't come across anything that is of use
to me. I want to configure Eclipse to use cygwin to make and build my C
programs, but I don't want to put cygwin in my path. It seems that
putting cygwin in my path actually messes up more than a few pieces of
software on my computer, so I just want to set it up for compiling in
eclipse.
Re: Cygwin Path [message #165546 is a reply to message #165539] |
Wed, 08 March 2006 22:51   |
Originally posted by: sscout.gmpexpress.net
Shawn Scout wrote:
> Duy Nguyen wrote:
>> That didn't work. It still claims at cygwin1.dll is missing (works
>> fine if I put the cygwin/bin folder in the system path, though).
>> I still don't want to add the cygwin/bin folder to my system path
>> because, as I said before, it seems that doing that interferes with a
>> few pieces of software that I use. I'm not too keen on finding
>> replacement software that'll work with cygwin, especially if cygwin
>> may interfere with new software I might install later.
> The trick is to configure the environment for your application, not for
> Eclipse/CDT. Open the Run menu and select "Run...". Choose your
> application from the list on the left. There should be an "Environment"
> tab, or something similar, on the right side (can't check right now; I'm
> having other issues with the CDT at the moment) - try adding cygwin/bin
> to the path in the application's environment. Should find the .dll
> fine, and you won't have to mess up your system/user environment to pull
> it off.
> Shawn
OK, got my CDT install working again after browsing the newsgroup for a
bit. Here's what I did on the "Run.." dialog.
- Select the project you are trying to run
- On the "Environment" tab, click the "Select.." button to add an
environment variable; select the PATH variable and click OK
- You should now see the PATH variable in the list; select it and
click the "Edit..." button
- Add your cygwin/bin directory (I prepended it to the path - I find
that I have fewer issues when I do this)
Now your application should run fine.
Shawn
Re: Cygwin Path [message #166029 is a reply to message #165515] |
Fri, 17 March 2006 13:54  |
Hello.
I want to establish exactly the same thing - to have CDT work with
Cygwin that is not present in the System enviroment. Everything seems to
work fine if you just add Cygwin/bin path everywhere enviroment is
settable (in Preferences/C_C++/Make/New make projects,
Preferences/C_C++/Managed build and Run...). You just select the prepend
option or type "c:\Progra~1\Cygwin\bin\;${env_var:PATH}".
Anyway.. With all this I managed to get the program to compile itself
and I can also run it in eclipse's console. But all the time I got a
warning in the Problems tab saying: "File not indexed because it was not
built" and every now and then (when I was playing around with settings)
another error showed up saying: "Error launching external scanner info
generator (gcc -E -P -v -dD
D:/Projects/.metadata/.plugins/org.eclipse.cdt.make.core/spe cs.c) ". To
sum up - compiling and running worked fine also with the errors and
after a while of playing around with settings also the error regarding
gcc went away, but it reappeared after restarting eclipse (it seems that
some Enviroment setups are mixed up and reused?).
Imho this problems are connected with the information gathering
mechanism that (as it looks) doesn't know where to find my gcc binary
(it doesn't use the Enviroment settings that can be set from within the
program). How to solve this?
(I created a Managed Make C Project in Eclipse SDK 3.1.2 with CDT 3.0.2)
gw
andy.green@nospam.oxsemi.com wrote:
>> use to me. I want to configure Eclipse to use cygwin to make and
>> build my C programs, but I don't want to put cygwin in my path. It
>> seems that putting cygwin in my path actually messes up more than a
>> few pieces of software on my computer, so I just want to set it up for
>> compiling in eclipse.
> In the 'environment' tab of the make builder, you can click 'select' and
> it gives you a selection of environment variables to set in the make
> shell. Just click/edit the ones you need.
> However I have an idea it may be better to set it in your system path,
> as I think eclipse uses the gcc toolchain to parse your code for
> completions/errors etc. Not sure - I haven't been playing for long enough.
FUDForum. Page generated in 0.10992 seconds
