Home » Eclipse Projects » GEF » Help with Palette
Help with Palette [message #165317] Mon, 24 January 2005 06:14 Go to next message
Originally posted by: ssc.acentic.net
I like to use the palette in a standalone swt application. Since I have
no clue how to do that, I looked for some examples and found this page
with some helloWorld examples. Unfortunately I am not able to get those
to run. Eclipse keeps on telling me this :
The type org.eclipse.ui.part.EditorPart cannot be resolved.
It is indirectly referenced from required .class files
Any idea, whats wrong ? BTW, the gef.jar is in the classpath.
Sebastian
Re: Help with Palette [message #165366 is a reply to message #165317] Mon, 24 January 2005 12:21 Go to previous messageGo to next message
Chances are that that example is quite old and hasn't been updated for
Eclipse 3.0 (where several packages were re-orged).
Add this to your plugin.xml and see if that makes a difference:
<import plugin="org.eclipse.core.runtime.compatibility" optional="true"/>
Eclipse.org has a migration guide to convert pre-3.0 plug-ins to be 3.0
compliant. Check that out. Also, if you right-click on the plugin.xml in
Package Explorer, you can go to PDE -> Migrate to 3.0.
If all you want to do is learn about the palette, why don't you try one of
the examples supported by GEF?
"Sebastian Scholz" <ssc@acentic.net> wrote in message
news:pan.2005.01.24.11.14.47.844000@acentic.net...
> Hi
> Sebastian
Re: Help with Palette [message #165406 is a reply to message #165366] Tue, 25 January 2005 02:49 Go to previous message
Thanks, I will try that.
Well, I was actually looking for a very simple implementation of a
palette somewhere, but all I found were those 2.x examples. All 3.x
examples are just plugins and as easy to understand,... guess I have
to go through these again.
To bad there are no such easy snippets available as they are for swt.
-Sebastian
Previous Topic:Mouse up event and request
Next Topic:Printing
Current Time: Mon Dec 01 13:22:55 EST 2025
Powered by FUDForum. Page generated in 0.04552 seconds
