Home » Eclipse Projects » Buckminster dev » How can I see if Resolution is from WS or TP?
How can I see if Resolution is from WS or TP? [message #15567] Wed, 23 April 2008 19:08 Go to next message
when getting Resolutions and presenting them in the new Component
Explorer View, I would like to separate the components into two major
groups, those that are in my workspace, and those in the target platform.
Is there some way to see that by looking at a Resolution?
- henrik
Re: How can I see if Resolution is from WS or TP? [message #15663 is a reply to message #15567] Thu, 24 April 2008 01:50 Go to previous messageGo to next message
Hi Henrik,
Yes there is. The resolution contains provider used and it in turn holds the id of the reader type.
Use the following snippet:
if(IReaderType.ECLIPSE_PLATFORM.equals(resolution.getProvide r().getReaderTypeId()))
// This component stems from the target platform
Henrik Lindberg wrote:
> Regards
> - henrik
Re: How can I see if Resolution is from WS or TP? [message #16913 is a reply to message #15663] Fri, 25 April 2008 06:10 Go to previous message
> the id of the reader type. Use the following snippet:
Worked like a charm. The Component Explorer now has two top level
folders - one for target platform, and one for workspace.
Checked in.
- henrik
Previous Topic:How can I get the OPML file?
Next Topic:Component Explorer and Component Outline
Current Time: Fri Nov 21 01:44:48 EST 2025
Powered by FUDForum. Page generated in 0.03950 seconds
