dtp and wst rdb [message #1294] |
Wed, 07 September 2005 17:38  |
What is different ?
I try install datatools (form current cvs) and
exists 2 'database explorer' and 'data output' view
I have connections from rdb, but it isn't visible in dtp
views
Re: dtp and wst rdb [message #1315 is a reply to message #1294] |
Tue, 13 September 2005 11:04   |
Originally posted by: jograham.sybase.com
snpe wrote:
> What is different ?
> views
Hi snpe:
The code in the DTP/CVS is currently in transition, with a major
refactoring being planned and incrementally implemented by the project
teams. Expect, for the time being, duplicate components and extension
points/API that will be changed going forward. DTP is currently planning
two milestone releases in 5Q4 and two more in 6Q1, with a release in late
6Q1. At each milestone point, as certain subset of functionality will be
in place, and this will be clearly documented in the release notes. At
present, the components closest to feature stability are those in the
Model Base project, though some changes could be expected as well.
John Graham
Eclipse DTP PMC Chair
Re: dtp and wst rdb [message #1888 is a reply to message #1875] |
Mon, 03 October 2005 16:45  |
Fred Grott wrote:
> So, basically at some point in the milestone relase shoudl see data
explorer/data output functionality that may be in WTp or JSR220 ORm as of now
moved and itnegrated with DTP with DTP becoming a base requirement for WTp and
JSR220_ORM?
Fred,
Yes, the DTP code line will continue to consolidate throughout the
milestone process, and current duplication within DTP will be eliminated.
For other projects, such as WTP and JSR220 ORM, I've heard that they too
will use the resultant DTP components, though I'll leave discussion about
the exact timing of such moves up to those projects themselves.
John Graham
Re: dtp and wst rdb [message #566482 is a reply to message #1294] |
snpe wrote:
> What is different ?
> views
Hi snpe:
John Graham
Re: dtp and wst rdb [message #566610 is a reply to message #1315] |
Mon, 03 October 2005 10:45  |
So, basically at some point in the milestone relase shoudl see data explorer/data output functionality that may be in WTp or JSR220 ORm as of now moved and itnegrated with DTP with DTP becoming a base requirement for WTp and JSR220_ORM?
Re: dtp and wst rdb [message #566635 is a reply to message #1875] |
JSR220_ORM?
Fred,
John Graham
FUDForum. Page generated in 0.09440 seconds
