Home » Eclipse Projects » Eclipse Platform » Changing the default JRE in WSAD5.1
Changing the default JRE in WSAD5.1 [message #164804] Tue, 02 December 2003 14:10 Go to next message
Hi All,
I need to change the default jre in wsad 5.1 The JRE presently shipped
with WSAD 5.1 is version 1.3.1. This does not support SSL by default. Does
ne one know how to change this to 1.4.2. I have tried setting this in the
Window->Preferences->Java->Installed JREs. I removed the default jre and
point the jre v 1.4.2. Well it still does not seem to pick it up. All my
system class path and path variables point to v 1.4.2. The default values
in WSAD can be viewed in Help-> About IBM .......-> Configuration Details.
I have tried the same with Eclipse 2.1 and it behaves normally. i.e if i
change the system JRE and point Eclipse to it, it does it up.
Where as in WSAD the new JRE is reflected only in the Run Time Workbench.
Any help is greatly appreciated.
thanx
Ajay
Re: Changing the default JRE in WSAD5.1 [message #165013 is a reply to message #164804] Tue, 02 December 2003 18:25 Go to previous message
Originally posted by: palistra.us.ibm.com
You might also try the WSAD newsgroups over at news.software.ibm.com
There are (at least) three JREs involved with WSAD. The JRE WSAD itself
runs on (1.3.1). The JRE for a given non-WAS project (by default the
same as the JRE WSAD runs on, but easy to switch). And the JRE that WAS
and WAS apps run on (JRE 1.3.1 inside of the WebSphere Test Environment
(WTE)).
You can change the one that non-WAS apps run on.
You can also make WSAD run on a different JRE, but that is not supported
and is probably not what you want.
You cannot change the JRE the WTE is running in. Well, you might be
able to force it to try to start, but I believe WAS checks when it
starts. Any anyway, the WTE is meant to be what WAS is running on in
production, which means the JRE that ships with WAS. WSAD 5.1 added the
J9 JVM for running WAS in debug for hot-method replace, but it is still
1.3.1.
WAS 5.1 was recently announced, which supports JDK 1.4.something.
Normally we try to keep the most current WTE in step with the most
current WAS.
I hope this helps - I was not sure which JRE you wanted to change.
Ajay wrote:
> Hi All,
> thanx
> Ajay
Jim Palistrant
IBM Worldwide Technical Consultant - WebSphere Development Tools
Previous Topic:Path resolution in Eclipse
Next Topic:cvs - no modules in HEAD
Current Time: Fri Nov 21 17:21:19 EST 2025
Powered by FUDForum. Page generated in 0.03066 seconds
