Home » Eclipse Projects » GEF » Multiple content panes possible??
Multiple content panes possible?? [message #164756] Thu, 20 January 2005 13:23 Go to next message
Hi!
Is there a way to set more than one content pane for an EditPart?
Depentend on the childs class, the appropriate pane should be selected.
Or can this be done an other way?
(Sorry for the bad English)
Re: Multiple content panes possible?? [message #164789 is a reply to message #164756] Thu, 20 January 2005 13:34 Go to previous messageGo to next message
For now, you need to override addChildVisual and just find the correct
content pane. Also, override:
public void setLayoutConstraint(EditPart child, IFigure childFigure, Object
constraint) {
childFigure.getParent().setConstraint(childFigure, constraint);
in Abstract GraphicaEditPart
"Roger VIllars" <roger.villars@mimacom.ch> wrote in message
news:csosvc$n80$1@www.eclipse.org...
> Hi!
> Depentend on the childs class, the appropriate pane should be selected. Or
Re: Multiple content panes possible?? [message #164901 is a reply to message #164789] Fri, 21 January 2005 01:20 Go to previous message
Hey, that worked! Too easy... ;-)
Thank you very much!
> constraint) {
>> Hi!
Previous Topic:Problems with CreationTool and disabled cursor
Next Topic:Connections as container for EditParts?
Current Time: Fri Nov 07 18:48:57 EST 2025
Powered by FUDForum. Page generated in 0.14232 seconds
