Home » Language IDEs » C / C++ IDE (CDT) » Standard Make C project with subfolders?
Standard Make C project with subfolders? [message #164498] Fri, 24 February 2006 06:15 Go to next message
Originally posted by: asd.asd.com
I have made a standard Make C Project. Now I would like this project to
contain a subfolder called "Assignments" which again contains the two
subfolders "assign1" and "assign2".
These two subfolder would contain 2 different sourcefiles each one having
its own unique makefile.
But this seems to be impossible in eclipse CDT 3.0.2. The reason appears
that a Standard Make C Project can only have one makefile associated with
it.
Is there somway to obtain the above filestructure that I described?
Johs
Re: Standard Make C project with subfolders? [message #164516 is a reply to message #164498] Fri, 24 February 2006 06:40 Go to previous messageGo to next message
> it.
> Johs
make and makefiles area reentrant.
You can call subfolders' makefiles from your main makefile
CC Vural
Re: Standard Make C project with subfolders? [message #164524 is a reply to message #164516] Fri, 24 February 2006 06:49 Go to previous messageGo to next message
>> it.
>> Johs
I have now made a Standard Make C Project called "myproject". In this
project I have made 2 sourcefolders: A,B. I have then put test1.c in A and
test2.c in B (the two test files have nothing to do with each other, they
are totally independant applications).
I have then made a makefile for test1.c and put it in folder A. I have also
made a makefile for test2.c that I have put in B.
Should I make a third makefile and put it in "myproject" where I can call
the two other makefiles from?
Re: Standard Make C project with subfolders? [message #164538 is a reply to message #164524] Fri, 24 February 2006 06:59 Go to previous messageGo to next message
>>> it.
>>> Johs
:-) yes
CC Vural
Re: Standard Make C project with subfolders? [message #164546 is a reply to message #164538] Fri, 24 February 2006 07:16 Go to previous messageGo to next message
>>>> having its own unique makefile.
>>>> appears that a Standard Make C Project can only have one makefile
>>>> associated with it.
>>>> Johs
>> and test2.c in B (the two test files have nothing to do with each other,
>> they are totally independant applications).
>> also made a makefile for test2.c that I have put in B.
> :-) yes
Ok here is the "main" makefile that I am trying to make:
test1:
make -I A/ test1
test2:
make -I B/ test2
But I just get no makefile found eventhough they are in A and B.
Re: Standard Make C project with subfolders? [message #164554 is a reply to message #164546] Fri, 24 February 2006 07:21 Go to previous messageGo to next message
>>>>> associated with it.
>>>>> Johs
>> :-) yes
> test1:
> make -I A/ test1
> test2:
> make -I B/ test2
You need to add ,
all : test1 test2
And change test?: as
cd A
make all
cd ..
CC Vural
Re: Standard Make C project with subfolders? [message #164562 is a reply to message #164554] Fri, 24 February 2006 07:32 Go to previous messageGo to next message
>>>>>> to contain a subfolder called "Assignments" which again contains the
>>>>>> two subfolders "assign1" and "assign2".
>>>>>> associated with it.
>>>>>> Johs
>>>> other, they are totally independant applications).
>>>> call the two other makefiles from?
>>> :-) yes
>> test1:
>> make -I A/ test1
>> test2:
>> make -I B/ test2
> You need to add ,
> all : test1 test2
> cd A
> make all
> cd ..
> Regards
> CC Vural
I now have:
all: test1 test2
test1:
cd g1
make all
cd ..
test2:
cd g2
make all
cd ..
in eclipse I have made a "Make Target": "build command": make test1
but when I build it goes on forever with this:
make[4]: *** [test1] Terminated
make[3]: *** [test1] Terminated
make[2]: *** [test1] Terminated
make[1]: *** [test1] Terminated
make: *** [test1] Terminated
Error launching builder (make test1 all )
(Command canceled)
what have I misunderstood?
Re: Standard Make C project with subfolders? [message #164585 is a reply to message #164562] Fri, 24 February 2006 08:18 Go to previous messageGo to next message
Sorry, my mistake
make auto changes to new diretories, so makefile in `test` diretory must be
all : test1 test2
clean :
make -f test1/makefile clean
make -f test2/makefile clean
test1 :
make -f test1/makefile all
test2 :
make -f test2/makefile all
CC Vural
>>>>>>> associated with it.
>>>>>>> Johs
>>>> :-) yes
>>> test1:
>>> make -I A/ test1
>>> test2:
>>> make -I B/ test2
>> You need to add ,
>> all : test1 test2
>> cd A
>> make all
>> cd ..
>> Regards
>> CC Vural
> I now have:
> all: test1 test2
> test1:
> cd g1
> make all
> cd ..
> test2:
> cd g2
> make all
> cd ..
> (Command canceled)
Re: Standard Make C project with subfolders? [message #164602 is a reply to message #164585] Fri, 24 February 2006 08:38 Go to previous messageGo to next message
> Sorry, my mistake
> be
What do you mean by 'test' dir, I never mentioned anything about a 'test'
dir?
> all : test1 test2
> clean :
> test1 :
> test2 :
> Regards
still does not work.
I have these files:
/home/johs/parent/makefile # The main make file
/home/johs/parent/g1/test1.c
/home/johs/parent/g1/makefile
/home/johs/parent/g2/test2.c
/home/johs/parent/g2/makefile
Now I would like to start EITHER the makefile in g2 or g1 with the main make
file. If I would like to start the makefile in g1, I would type:
make test1
from the '/home/johs/parent/' dir.
The content of my main make file is:
all: test1 test2
clean :
make -f g1/makefile clean
make -f g2/makefile clean
test1 :
make -f g1/makefile all
test2 :
make -f g2/makefile all
and the content of the makefile in /home/johs/parent/g1/ is:
CC=gcc
CFLAGS=-g -pthread
all: test1
test: test1.c
$(CC) $(CFLAGS) test1.c -o test1
clean:
rm -rf *o test1
....it seems that calling another makefile in another dir with a makefile is
not the best way to make it work.
Re: Standard Make C project with subfolders? [message #164610 is a reply to message #164585] Fri, 24 February 2006 08:46 Go to previous message
> Sorry, my mistake
> be
> all : test1 test2
> clean :
> test1 :
> test2 :
> Regards
> CC Vural
>>>>>>>> project to contain a subfolder called "Assignments" which again
>>>>>>>> contains the two subfolders "assign1" and "assign2".
>>>>>>>> associated with it.
>>>>>>>> Johs
>>>>>> A and test2.c in B (the two test files have nothing to do with each
>>>>>> have also made a makefile for test2.c that I have put in B.
>>>>> :-) yes
>>>> test1:
>>>> make -I A/ test1
>>>> test2:
>>>> make -I B/ test2
>>> You need to add ,
>>> all : test1 test2
>>> cd A
>>> make all
>>> cd ..
>>> Regards
>>> CC Vural
>> I now have:
>> all: test1 test2
>> test1:
>> cd g1
>> make all
>> cd ..
>> test2:
>> cd g2
>> make all
>> cd ..
>> (Command canceled)
This works:
all: test1 test2
test1 :
cd g1 && $(MAKE) test1
test2 :
cd g2 && $(MAKE) test2
Previous Topic:Slow content assist with qt
Next Topic:How to set environment variables when building?
Current Time: Sat Jul 12 20:04:42 EDT 2025
Powered by FUDForum. Page generated in 0.05310 seconds
