Home » Newcomers » Newcomers » Runtime problem
Runtime problem [message #164456] Tue, 08 August 2006 04:21 Go to next message
Originally posted by: zor.zor.com
I'm adding a JAR file to my eclipse application using "add external
jar" . But while it compile the program with no problem, during the
running of the program it can not find the classes that are part of the
JAR.
What am I missing?!
Yoni.
Re: Runtime problem [message #164480 is a reply to message #164456] Tue, 08 August 2006 04:53 Go to previous messageGo to next message
Yoni,
> JAR.
> What am I missing?!
> Yoni.
You need to add the JAR file to the runtime class path.
To do that, select "Run..." from the "Run" menu, select the launch
configuration for your Java class, switch to the Classpath page, select
the "User Entries" node, and click the "Add External JARs" button to add
the JAR file to your classpath.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, Platform Project (JVMTI Profiler)
Re: Runtime problem [message #164496 is a reply to message #164480] Tue, 08 August 2006 05:35 Go to previous messageGo to next message
Asaf,
Thank you for the quick answer... However there is no classpath page.
I'm using eclipse 3.2 and I'm building an Eclipse Application. You have
classpath page if you are developing a "Java Bean" or "Java
Application" but not for "Eclipse Application" ... Am I missing
something?!?
Yoni.
Asaf Yaffe wrote:
> Yoni,
> > Hi,
> > the JAR.
> > What am I missing?!
> > Thanks,
> > Yoni.
> select the "User Entries" node, and click the "Add External JARs"
> button to add the JAR file to your classpath.
> HTH,
> Asaf
Re: Runtime problem [message #164503 is a reply to message #164496] Tue, 08 August 2006 06:03 Go to previous messageGo to next message
Yoni,
I understand that you are creating an Eclipse plugin. I don't have a lot
of experience in plugin development, but I think you can specify the JAR
files used by your plugin in the plugin configuration file (plugin.xml):
Double click plugin.xml (should be located in the root of your plugin
project), select the "Runtime" tab in the editor, and add the required
JAR files in the "classpath" section. You may want to add these JAR
files to your project (usually in a 'lib' directory) so you can add them
to the classpath using a path name relative to your plugin direcory.
HTH,
Asaf
Asaf Yaffe
Re: Runtime problem [message #164745 is a reply to message #164456] Wed, 09 August 2006 05:30 Go to previous messageGo to next message
Yoni Zor wrote:
>Hi,
>JAR.
>What am I missing?!
Where is the external JAR? If it is not in your plug-in then you have to
bundle bundle it first. Check older threads about this.
Dani
>Thanks,
>Yoni.
Re: Runtime problem [message #164950 is a reply to message #164503] Thu, 10 August 2006 05:34 Go to previous message
It seems that I had to both add it threw the plugin and put it in the
root of the project.
Asaf Yaffe wrote:
> Yoni,
> lot of experience in plugin development, but I think you can specify
> the JAR files used by your plugin in the plugin configuration file
> (plugin.xml): Double click plugin.xml (should be located in the root
> of your plugin project), select the "Runtime" tab in the editor, and
> add the required JAR files in the "classpath" section. You may want
> to add these JAR files to your project (usually in a 'lib' directory)
> so you can add them to the classpath using a path name relative to
> HTH,
> Asaf
Previous Topic:'links' directory and plugin locations
Next Topic:FREE Eclipse Magazine Download
Current Time: Sat Oct 25 15:43:11 EDT 2025
Powered by FUDForum. Page generated in 0.08661 seconds
