Search for calls to specific constructor in class? [message #164370] |
Mon, 07 August 2006 14:00  |
Using Eclipse 3.1.2 and JDK 1.4.2.
In the Java Search options, I can search for calls to a constructor
matching the search string. This will find references to any constructor
for the class matching the search string.
Is it possible to limit the search so that it only finds references to
specific constructors of the class? I don't see a way to do that, unless
it's some magic in the entered search string. I tried entering
"ClassName(String,String)", to indicate that I wanted to find references
to the constructor that takes 2 strings, but the "Search" button greyed
out when I entered the ",".
Re: Search for calls to specific constructor in class? [message #164385 is a reply to message #164370] |
Mon, 07 August 2006 14:49  |
Select the constructor in the Outline view, right click, and select
References. You can specify the scope of the search on the popup menu.
You can also do the same thing if you right click on the definition of the
constructor in your source code.
You may also want to try the Open Call Hierarchy from the popup menu.
This allows you to trace back the path used to get to calling the
constructor.
FUDForum. Page generated in 0.08806 seconds
