Home » Archived » BIRT » WARNING: Invalid line height: normal
WARNING: Invalid line height: normal [message #164358] Wed, 24 May 2006 15:46 Go to next message
Originally posted by: ejf7.hotmail.com
I'm getting this warning when I run reports through the report engine. I'm
using report engine API version 2.1RC2. This warning displays 16 times for
every item retrieved by my SELECT statement.
My report consists of a 6X9 grid in a detail section of a 1X1 table.
All of my row heights in my grid are defined as numerical values.
The complete warning is as follow:
WARNING: invalid line height: normal
{date/time} org.eclipse.birt.report.engine.layout.util.PropertyUtil
getLineHeight
If my SELECT statement retrieves a lot of data, after it gives the warning
a couple hundred times, I get a java.lang.OutOfMemoryError exception.
It doesn't give this warning when I run it from Eclipse, just when the
report engine runs it.
Anyone? [message #164846 is a reply to message #164358] Thu, 25 May 2006 17:56 Go to previous message
Does anyone have a solution for this problem?
Previous Topic:BIRT formatting functions in javascript
Next Topic:Barcode Font 3 of 9
Current Time: Fri Jul 18 12:54:37 EDT 2025
Powered by FUDForum. Page generated in 0.12030 seconds
