Home » Archived » M2M (model-to-model transformation) » ANTLR class not found in the ATL plugin
ANTLR class not found in the ATL plugin [message #15457] Tue, 06 February 2007 11:16 Go to next message
Originally posted by: yann.croguennec.gmail.com
I begin to work with ATL. During the tutorial, I can't do "Inject KM3 to
ECore metamodel". When I look inside the Eclipse Error View, I have the
following exception :
java.lang.NoClassDefFoundError: antlr/TokenStream
at java.lang.ClassLoader.defineClass1(Native Method)
However, I copy the antlr.jar file inside the
$eclipse\plugins\org.atl.eclipse.engine_1.0.7\lib
Does anyone can help me ?
Thank you in advance
Yann
[ATL] Re: ANTLR class not found in the ATL plugin [message #15490 is a reply to message #15457] Tue, 06 February 2007 11:27 Go to previous messageGo to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Yann,
Maybe you need to run Eclipse with "-clean" option to refresh the
configuration after adding new things.
Freddy.
yann.croguennec@gmail.com a écrit :
> Hello,
> Yann
Re: [ATL] Re: ANTLR class not found in the ATL plugin [message #15522 is a reply to message #15490] Tue, 06 February 2007 11:34 Go to previous message
Freddy Allilaire a écrit :
> Hi Yann,
> Freddy.
Thank you for the tips, it works.
Yann
Previous Topic:on the navigation of the target model in an ATL transformation
Next Topic:UML Profiles and ATL - couple of questions
Current Time: Sun Nov 09 02:49:29 EST 2025
Powered by FUDForum. Page generated in 0.02510 seconds
