Home » Language IDEs » Java Development Tools (JDT) » Run Ant oddities
Run Ant oddities [message #163985] Fri, 11 June 2004 13:42 Go to next message
Using RC1 I have a user who when selecting on one "build.xml" see the
following when right clicking on the build.xml file.
One has Run --> Ant Build
Ant Build
External Tools
But when selecting a different build.xml file, it just has Run (which
brings up the run config).
Why a different behavior from build.xml to build.xml???
Re: Run Ant oddities [message #163993 is a reply to message #163985] Fri, 11 June 2004 14:58 Go to previous messageGo to next message
"mike shipkowski" <michael.shipkowski@sas.com> wrote in message
news:cacquc$mnh$1@eclipse.org...
> Ant Build
> External Tools
This would be the menu presented if the build.xml has "valid" Ant buildfile
content.
That is it has a root element that is a "project".
Since the content has been deemed to be a Ant buildfile, the options to
perform an Ant build are presented
This build.xml does not have a root project element.
Since the content is not deemed to be an Ant buildfile, no options are
presented to perform an Ant build.
If this is not the case for your user, please log a reproducible test case
against platform ant.
HTH
Darins
Re: Run Ant oddities [message #164000 is a reply to message #163993] Fri, 11 June 2004 14:18 Go to previous messageGo to next message
Could you expand on what "root project element." means?? Is this a
location in the project???
> > Ant Build
> > External Tools
> content.
> HTH
> Darins
Re: Run Ant oddities [message #164007 is a reply to message #164000] Fri, 11 June 2004 14:58 Go to previous messageGo to next message
The syntax required by Ant to be considered a valid buildfile.
<project name="My Buildfile" default="build" basedir="..">
<!--rest of your buildfile goes in here..including your default target
build-->
</project>
The root element is the project element.
HTH
Darins
news:cact15$p9m$1@eclipse.org...
> > > Ant Build
> > > External Tools
buildfile
> > content.
case
> > HTH
> > Darins
Re: Run Ant oddities [message #164042 is a reply to message #164000] Fri, 11 June 2004 15:27 Go to previous messageGo to next message
The problem goes away if a comment prior to the project xml line is
removed....this seems to be an error in thea the comment should be
ignored....
> > > Ant Build
> > > External Tools
> > content.
> > HTH
> > Darins
Re: Run Ant oddities [message #164074 is a reply to message #164042] Fri, 11 June 2004 15:49 Go to previous message
We did have a bug in determination of content type (but I am pretty sure
this was fixed before RC1 and does not sound the same as what you are
describing)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=63298
maybe we have others...
Can you provide a sample buildfile (in a bug or here) so that I can test on
the RC2 candidate?
Darins
news:cad12r$tk1$1@eclipse.org...
> ignored....
the
> > > > Ant Build
> > > > External Tools
buildfile
> > > content.
to
(which
case
> > > HTH
> > > Darins
Previous Topic:Multiple locations for a JAR sourcepath
Next Topic:Eclipse don't stop in breakpoints
Current Time: Wed Nov 05 06:13:10 EST 2025
Powered by FUDForum. Page generated in 0.04191 seconds
