Home » Eclipse Projects » DSDP - Target Management » RSE Limit cache size, maximum cache size 0
RSE Limit cache size, maximum cache size 0 [message #15446] Tue, 09 October 2007 09:27 Go to next message
Originally posted by: davisons.qwest.com
Just curious, what affect does the subject line setting have on file
caching?
Stephen
Re: RSE Limit cache size, maximum cache size 0 [message #15479 is a reply to message #15446] Tue, 09 October 2007 16:53 Go to previous messageGo to next message
Hi Stephen,
If you limit the cache size to a maximum of 0, then RSE will try to delete
all temp files that have not been recently used. Files that are open or
have been in use during the session are not deleted.
Dave
"Stephen Davison" <davisons@qwest.com> wrote in message
news:fefvjl$dg2$1@build.eclipse.org...
> caching?
> Stephen
Re: RSE Limit cache size, maximum cache size 0 [message #15512 is a reply to message #15479] Fri, 12 October 2007 13:32 Go to previous message
David,
Thanks for the reply. One of these days I'll have to get the source code
and start answering questions for myself. :-)
For whatever it's worth, I'd like to say Thank You to the DSDP/TM team for
developing a great product.
RSE has been very helpful for me converting from HomeSite+ to Eclipse with
CFEclipse. The group I work in uses HomeSite+ to edit ColdFusion templates
under the development server's source tree. We're doing more Java web
application development now and having RSE has allowed me to get immersed in
Eclipse by doing all of my development there.
Thanks again,
Stephen
"David McKnight" <dmcknigh@ca.ibm.com> wrote in message
news:fegpor$o9l$1@build.eclipse.org...
> Hi Stephen,
> Dave
>> caching?
>> Thanks,
>> Stephen
Re: RSE Limit cache size, maximum cache size 0 [message #570409 is a reply to message #15446] Tue, 09 October 2007 16:53 Go to previous message
Hi Stephen,
Dave
> caching?
> Stephen
Re: RSE Limit cache size, maximum cache size 0 [message #570479 is a reply to message #15479] Fri, 12 October 2007 13:32 Go to previous message
David,
Thanks again,
Stephen
> Hi Stephen,
> Dave
>> caching?
>> Thanks,
>> Stephen
Previous Topic:RSE Limit cache size, maximum cache size 0
Next Topic:Orphaned Terminal window
Current Time: Sat Nov 22 11:31:37 EST 2025
Powered by FUDForum. Page generated in 0.05577 seconds
