Using the "pde.build" target of generated ant scripts [message #1281] |
Fri, 18 April 2008 10:43  |
Originally posted by: le_nemo.yahoo.fr
I am trying to use the "pde.build" target of ant scripts generated by
PDE. I use the command specified in the the documentation. In my case,
it is :
java -Xmx1024m -jar
/opt/eclipse/plugins/org.eclipse.equinox.launcher_1.0.1.R33x _v20080118.jar
-application org.eclipse.ant.core.antRunner -buildfile
/full/path/to/my/project/build.xml -target main
The scripts are running well, until :
fetchElement:
BUILD FAILED
/full/path/to/my/project/build.xml:34: The following error occured
while executing this line:
/full/path/to/my/project/build.xml:77: The following error occured
/full/path/to/my/project/customTargets.xml:10: The following error
occured while executing this line:
/full/path/to/my/project/allElements.xml:12: The following error
/full/path/to/my/project/genericTargets.xml:42: Problem: failed to
create task or type eclipse.fetch
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/type have been declared.
Action: CHeck that any <presetdef>/<macrodef> declarations have taken
place.
I looked in the genericTargets.xml at line 42, and it seems to be all
right (this file is generated by PDE).
Is there something i did wrong ?
The scripts are executed on a GNU/Linux machine, with Eclipse 3.3.2
(Europa).
Thank you,
Francois-Xavier Bru
Re: Using the "pde.build" target of generated ant scripts [message #1878 is a reply to message #1303] |
Mon, 21 April 2008 04:38  |
Thank you for your answer,
I don't know why today the problem is resolved. As you say, something
was surely missing, or the paths were not up to date. So i'm sorry for
disturbing you.
But your suggestion to look at the osgi console when problems happens
will be helpfull for me.
Good bye
Dans son message précédent, Andrew Niefer a écrit :
> "eclipse.fetch" is a custom task provided by org.eclipse.pde.build. It is
> expected that the org.eclipse.ant.core.antRunner application will set up the
> ant classpaths properly so that this and other custom tasks are found
> properly.
> Does /opt/eclipse contain a full eclipse install?
> You could try running something like
> java -jar plugins/org.eclipse.equinox.launcher_1.0.1.R33x_v20080118.ja r
> -application org.eclipse.ant.core.antRunner -console -noexit
> And at the osgi console, type "ss org.eclipse.pde.build" to see if the
> pde.build is active or at least resolved.
> -Andrew
> Francois-Xavier Bru wrote:
>> Hello,
>> I am trying to use the "pde.build" target of ant scripts generated by PDE.
>> I use the command specified in the the documentation. In my case, it is :
>> java -Xmx1024m -jar
>> fetchElement:
>> BUILD FAILED
>> /full/path/to/my/project/build.xml:34: The following error occured while
>> /full/path/to/my/project/build.xml:77: The following error occured while
>> /full/path/to/my/project/customTargets.xml:10: The following error occured
>> /full/path/to/my/project/allElements.xml:12: The following error occured
>> /full/path/to/my/project/genericTargets.xml:42: Problem: failed to create
>> place.
>> I looked in the genericTargets.xml at line 42, and it seems to be all right
>> (Europa).
>> Thank you,
>> Francois-Xavier Bru
Re: Using the "pde.build" target of generated ant scripts [message #565877 is a reply to message #1281] |
Fri, 18 April 2008 16:00  |
expected that the org.eclipse.ant.core.antRunner application will set up the ant
classpaths properly so that this and other custom tasks are found properly.
And at the osgi console, type "ss org.eclipse.pde.build" to see if the pde.build
-Andrew
> Hello,
> it is :
> java -Xmx1024m -jar
> fetchElement:
> BUILD FAILED
> place.
> (Europa).
> Thank you,
> Francois-Xavier Bru
Re: Using the "pde.build" target of generated ant scripts [message #566024 is a reply to message #1303] |
disturbing you.
Good bye
> properly.
> -Andrew
>> Hello,
>> java -Xmx1024m -jar
>> fetchElement:
>> BUILD FAILED
>> place.
>> (Europa).
>> Thank you,
>> Francois-Xavier Bru
FUDForum. Page generated in 0.08749 seconds
