| Node location problem in "Diagram Partitioning" in switching from an editor to the other [message #163396] |
Fri, 30 November 2007 03:28  |
Originally posted by: frogneux.lippmann.lu
Hi everybody,
We are implmenting a diagram partitioning feature in our editor.
Everything is ok but we have a problem with the location of elements.
Explaination: We have a "supereditor" and a "subeditor". Our supereditor
is a global view of all elements in the model. Our subeditor is openned
by double-clicking on a node, and allows us to see only this part of our
full model. Our problem relates on locations of different elements which
we can add.
Imagine, we add a node in the sub editor and move it to a certain
location on the canvas. We save the subeditor diagram, and then open the
supereditor. The added node is graphically there but its location is
ALWAYS at coordinates [0,0] , so the original position is not remained.
Please note that the real location of the node is written in the xmi
file giving the graphical properties. We'd like to get the same position
for elements in the two editors while switching from one to the other.
Any hint ? Any help ?
Etienne
| Re: Node location problem in "Diagram Partitioning" in switching from an editor to the oth [message #163432 is a reply to message #163396] |
Fri, 30 November 2007 08:09   |
Hi Etienne,
A possible solution could be to use "arrange all" right after opening
the super-diagram if there are elements with uninitialized bounds. This
will not guarantee the synchronized positions, but at least nodes will
not overlap.
If you need to always have synchronized locations, you could use a
shared editing domain and register a ResourceSetListener that would
update coordinates in the super-editor in response to the corresponding
modifications in the sub-editor (and probably vice versa?). Note
however, that this could make them overlap with nodes that are not shown
in the sub-diagram.
Boris
Etienne Frogneux wrote:
> Hi everybody,
> we can add.
> Thanks
> Etienne
| Re: Node location problem in "Diagram Partitioning" in switching from an editor to the oth [message #163881 is a reply to message #163432] |
Mon, 03 December 2007 11:40  |
Hi Boris,
Thanks a lot for your answer.
How do you realize your first proposition("arrange all" utilisation)?
I think you call a method(arrangeAll?), but where? I don't have any ideas!
Etienne
Boris Blajer a écrit :
> Hi Etienne,
> not overlap.
> in the sub-diagram.
> Best regards,
> Boris
>> Hi everybody,
>> supereditor is a global view of all elements in the model. Our
>> subeditor is openned by double-clicking on a node, and allows us to
>> see only this part of our full model. Our problem relates on locations
>> of different elements which we can add.
>> the supereditor. The added node is graphically there but its location
>> is ALWAYS at coordinates [0,0] , so the original position is not
>> remained. Please note that the real location of the node is written in
>> the xmi file giving the graphical properties. We'd like to get the
>> same position for elements in the two editors while switching from one
>> to the other.
>> Thanks
>> Etienne
FUDForum. Page generated in 0.04009 seconds
