Home » Language IDEs » ServerTools (WTP) » eclipse corrupted after installing 1.5M5!
eclipse corrupted after installing 1.5M5! [message #163375] Thu, 09 March 2006 03:37 Go to next message
Originally posted by: gee_hell.hotmail.com
I've just upgraded from 1.5M4 (which was well working) to 1.5M5 and now my
Eclipse seems to be corrupted :
I've a problem notified on my dynamic web project : "CHKJ3000E: WAR
Validation Failed:
org.eclipse.jst.j2ee.commonarchivecore.internal.exception.De ploymentDescriptorLoadException:
WEB-INF/web.xml".
More disturbing, I'm not able to open the JSP editor. I have the following
message "Unable to create this part due to an internal error. Reason for
the failure: The editor class could not be instantiated. This usually
indicates that the editor's class name was mistyped in plugin.xml.", with
the stacktrace below...
Please, does someone know what's wrong, or how I can came back to 1.5M4??
TIA
org.eclipse.wst.sse.ui.StructuredTextEditor.createCombinedPr eferenceStore(StructuredTextEditor.java:1427)
org.eclipse.wst.sse.ui.StructuredTextEditor.initializeEditor (StructuredTextEditor.java:2332)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.<init >(AbstractDecoratedTextEditor.java:216)
at org.eclipse.ui.editors.text.TextEditor.<init>(TextEditor.java:66)
org.eclipse.wst.sse.ui.StructuredTextEditor.<init>(StructuredTextEditor.java:1063)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:162)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:240)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:236)
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:252)
org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:842)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:562)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:384)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1102)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1051)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 56)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:442)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:109 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:60)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:212)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:202)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:758)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:665)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:628)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2360)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2295)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2287)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2273)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2268)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2249)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:251)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:131)
org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:16 9)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:15 3)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:222)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:198)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:296)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:869)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:741)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:739)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:968)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1067)
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:243)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:238)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:277)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: eclipse corrupted after installing 1.5M5! [message #163383 is a reply to message #163375] Thu, 09 March 2006 03:45 Go to previous messageGo to next message
Before being asked, my version of Eclipse is :
Version 3.1.1
Build id M20050929-0840
Re: eclipse corrupted after installing 1.5M5! [message #163473 is a reply to message #163383] Thu, 09 March 2006 12:18 Go to previous message
Originally posted by: gamigin.gmail.com
Try using Eclipse 3.2M5. WTP 1.5 M5 is built for that version and I don't
believe that the older 3.1.1 is supported.
Previous Topic:WTP update failed
Next Topic:Tomcat starts okay, but doesn't work
Current Time: Mon Jul 21 22:11:09 EDT 2025
Powered by FUDForum. Page generated in 0.04892 seconds
