Home » Language IDEs » C / C++ IDE (CDT) » Multiple users with different compilers and setting
Multiple users with different compilers and setting [message #163065] Thu, 02 February 2006 16:44 Go to next message
Originally posted by: berend.chalmers.se
I am working on a project with multiple users involved, and each
update/commit the same project to a CVS server.
However, each user has its own settings under project Properties->C++
Build (different compiler flags, paths etc.). What is the best way to
make use of CVS for the source files, but not for the project properties
(as is default).
Berend.
Re: Multiple users with different compilers and setting [message #163087 is a reply to message #163065] Fri, 03 February 2006 01:29 Go to previous messageGo to next message
Originally posted by: Martin.eisengardt.de
Do not share your project files. (.project / .cdtproject) but your source
folders. For example everyone can create his own project and checkout the
source folders via "Check out into"
"Berend van Wachem" <berend@chalmers.se> schrieb im Newsbeitrag
news:drtued$phm$1@utils.eclipse.org...
> Build (different compiler flags, paths etc.). What is the best way to make
> use of CVS for the source files, but not for the project properties (as is
> default).
> Berend.
Re: Multiple users with different compilers and setting [message #163129 is a reply to message #163087] Fri, 03 February 2006 15:58 Go to previous messageGo to next message
How do I exclude the projectfiles from the CVS update? I cannot even see
the projectfiles in the Projects overview.
Berend.
>>Hi,
>>default).
>>Thanks,
>>Berend.
Re: Multiple users with different compilers and setting [message #163137 is a reply to message #163129] Sat, 04 February 2006 03:07 Go to previous messageGo to next message
Hi.
You will see them in the resources perspective. Add them to .cvsignore.
Ciao
Martin
news:ds0g4h$gv7$1@utils.eclipse.org...
> Berend.
>>>Hi,
>>>(as is default).
>>>Thanks,
>>>Berend.
Re: CVS functionality [message #164130 is a reply to message #163137] Mon, 20 February 2006 10:21 Go to previous message
I am still having trouble with sharing the project with CVS and other
users. I have made a .cvsignore file with the contents:
..cdt*
..setting*
*org.eclipse*
But everytime I update/commit, the CVS complains that the directory
".settings" and the file in it (org.eclipse.cdt.managedbuilder.core.prefs).
are not in sync with the repository. Why doesn't the CVS leave that
file/dir alone now? How do I get such a dir and file out of CVS?
Another thing, is that when a fresh copy of the project (C/Managed Make)
is checked out, and one wants to edit the build settings, eclipse gives
the error:
The managed make project file could not be read because of the following
error:
The managed make project file is missing.
I guess this is because the file .cdtbuild etc no longer are in the
project. But how can a new copy in eclipse get some "standard" settings
in the managed make menu?
Thanks!
Berend.
> Ciao
> Martin
>>Thanks,
>>Berend.
>>>>Hi,
>>>>(as is default).
>>>>Thanks,
>>>>Berend.
L_@~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~@
| Berend van Wachem |
| Multiphase Flow Group |
| Chalmers University of Technology |
| Please note that my email address has changed to: |
| Berend@chalmers.se |
| Please make the appropriate changes in your address |
| list. |
__@~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~@
\/______________________________________________________/
Previous Topic:settings/compile question
Next Topic:DLL application import problem
Current Time: Fri Nov 21 21:08:27 EST 2025
Powered by FUDForum. Page generated in 0.03943 seconds
