Home » Archived » BIRT » call java
call java [message #163053] Fri, 19 May 2006 13:36 Go to next message
Originally posted by: wohlgemuth.ucdavis.edu
hi,
does somebody have an extended tutorial how to call java out of birt, the
basic description is kinda short. Basicly I have a jdbc dataset and want to
calculate a column
so like:
value = calculate(returnedValue by query)
regards,
gert
Re: call java [message #163124 is a reply to message #163053] Fri, 19 May 2006 17:08 Go to previous message
ok I found out how it works,
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="SPECTRA" id="95">
<text-property name="displayName">SPECTRA</text-property>
<list-property name="computedColumns">
<structure>
<property name="name">HEIGHT</property>
<expression name="expression">var ion = row["ION"];
var spectra = row["SPECTRA"];
calculate = new
Packages.edu.ucdavis.genomics.metabolomics.binbase.bdi.util. math.CalculateSpectraProperties(spectra);
calculate.calculateHeight(ion);</expression>
<property name="dataType">float</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">BIN</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">DATUM</property>
<property name="dataType">date-time</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">SAMPLE</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">SPECTRA</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ION</property>
<property name="dataType">decimal</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">AMMOUNT</property>
</structure>
<structure>
<property name="position">7</property>
</structure>
</list-property>
</structure>
<property name="dataSource">binbase</property>
<property name="queryText">select *
from DATA</property>
</oda-data-set>
"gert wohlgemuth" <wohlgemuth@ucdavis.edu> wrote in message
news:e4kvjf$92f$1@utils.eclipse.org...
> hi,
> to calculate a column
> so like:
> regards,
> gert
Previous Topic:how to manipulate DataSet results
Next Topic:How to script HTML constrols (drop-downs, radio buttons)
Current Time: Thu Jul 17 22:12:39 EDT 2025
Powered by FUDForum. Page generated in 0.05038 seconds
