Home » Archived » EPF » EPF Error - JVM Terminated
EPF Error - JVM Terminated [message #15343] Thu, 29 June 2006 08:27 Go to next message
I have observed that the EPF Composer (M3 build) suddenly exits showing
the following message in a window:
JVM Terminated. Exit code=1.
-Xms64m
-Xmx512m
This happens when
1. I add/modify/delete some content in WBS for a process
2. Modify the Activity or Activity Details diagrams in EPF.
- Is that because of the stability issues in the EPF build?
- Is there any fix to this?
Please suggest.
Re: EPF Error - JVM Terminated [message #15376 is a reply to message #15343] Thu, 29 June 2006 11:31 Go to previous message
Originally posted by: storaskar.xx.xxx.xxx
Hi Ravindra
Please file a bug for this, mentioning detailed steps that you are doing
which leads to this JVM termination.
Additional pointers to mention
- Can you reproduce consistently
- How often do you see this
- Are you running the application for long time before seeing this
- Are you working with CM ? (eg. CVS)
If you can attach the .log file when you see this JVM termination, it will
be helpful for us. Your workspace directory will have .log under
/.metadata folder.
Re: EPF Error - JVM Terminated [message #564417 is a reply to message #15343] Thu, 29 June 2006 11:31 Go to previous message
Hi Ravindra
/.metadata folder.
Previous Topic:EPF Error - JVM Terminated
Next Topic:Search Engine
Current Time: Wed Jul 16 02:50:44 EDT 2025
Powered by FUDForum. Page generated in 0.04698 seconds
