Home » Archived » BIRT » Excel Export as PDF and HTML
Excel Export as PDF and HTML [message #162947] Fri, 19 May 2006 10:11 Go to next message
How can I export to Excel like PDF and HTML. Is there any emileter for
Excel.
How can I find it?
Re: Excel Export as PDF and HTML [message #163092 is a reply to message #162947] Fri, 19 May 2006 14:56 Go to previous message
There is no official "Export to Excel" option yet.
However, someone did create a 'plugin' that enables "Exporting to Excel".
This site contains info & instructions for getting that to work:
http://qauck.blogspot.com/
It is still in development and the results are hit or miss (some quirky
formatting, data overlapping multiple columns, etc). Feel free to try it
out for yourself though. I believe a new version is on the way. Also,
the BIRT Viewer has the option to export a single dataset to .csv.
Alternatively, you can interact directly with the BIRT API in a JAVA
program to do your own .csv exporting. Read the "IDataExtractionTask"
section on:
http://www.eclipse.org/birt/phoenix/deploy/reportEngineAPI.p hp
This is also the bugzilla entry for this request. No responses since
2005-06-07 though:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=98661
Previous Topic:pdf rendering
Next Topic:Report engine cannot create pdf emitter
Current Time: Fri Nov 07 03:14:45 EST 2025
Powered by FUDForum. Page generated in 0.27727 seconds
