Home » Language IDEs » Java Development Tools (JDT) » ECLIPSE2.1 Problems viewing Java Source - Class Not Def Error
ECLIPSE2.1 Problems viewing Java Source - Class Not Def Error [message #162927] Sat, 05 June 2004 10:37
Originally posted by: pate-carolan.juno.com
Has anybody seen this error message before...
!ENTRY org.eclipse.ui.workbench 4 2 Jun 05, 2004 10:06:25.674
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/compare/ITypedElement
org.eclipse.jdt.internal.ui.compare.LocalHistoryActionGroup. <init>(LocalHist
oryActionGroup.java:35)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .createActions(C
ompilationUnitEditor.java:664)
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextE
ditor.java:2083)
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEdito
r.java:53)
org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.createPart Control(JavaEdit
or.java:2050)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .createPartContr
ol(CompilationUnitEditor.java:1008)
at org.eclipse.ui.internal.PartPane$4.run(PartPane.java:141)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:137)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :186)
org.eclipse.ui.internal.EditorWorkbook.createPage(EditorWork book.java:387)
at org.eclipse.ui.internal.EditorWorkbook.add(EditorWorkbook.ja va:123)
at org.eclipse.ui.internal.EditorArea.addEditor(EditorArea.java :55)
org.eclipse.ui.internal.EditorPresentation.openEditor(Editor Presentation.jav
a:351)
at org.eclipse.ui.internal.EditorManager$2.run(EditorManager.ja va:585)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:574
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:
668)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager
..java:459)
org.eclipse.ui.internal.EditorManager.openEditorFromInput(Ed itorManager.java
:333)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:424)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2056
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2004)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:1991)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1986)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1887)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtil
ity.java:133)
ity.java:111)
org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:
47)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:15 8)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:14 7)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDisp
atchAction.java:191)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchActi
on.java:169)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpe
n(PackageExplorerActionGroup.java:324)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageEx
plorerPart.java:323)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:397)
:1006)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:39
5)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:
605)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.jav
a:694)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:209)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:204)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:233)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:810)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:832)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:817)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:5 42)
at org.eclipse.swt.widgets.Tree.mouseDoubleClick(Tree.java:999)
at org.eclipse.swt.widgets.Tree.handleEvents(Tree.java:817)
org.eclipse.swt.widgets.SelectableItemWidget$1.handleEvent(S electableItemWid
get.java:1196)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2148)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1914)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Previous Topic:is there any sense of a project file ?
Next Topic:Bug in JUnit TestSuite?
Current Time: Sun Jul 13 23:15:07 EDT 2025
Powered by FUDForum. Page generated in 0.03438 seconds
