Home » Language IDEs » ServerTools (WTP) » toString() generator available?
toString() generator available? [message #162746] Fri, 03 March 2006 08:24 Go to next message
Originally posted by: grm7790.yahoo.com
Is there an automatic toString() generator available (or planned) by
default in WTP? It would be nice if this feature was available "out of
the box" in WTP so we wouldn't need to download a plugin for it.
Glen
Re: toString() generator available? [message #162763 is a reply to message #162746] Fri, 03 March 2006 10:31 Go to previous messageGo to next message
> Glen
toString(), hashCode() and equals() generator exists in Eclipse 3.2M5!
Kind regards,
Daniel
Re: toString() generator available? [message #162771 is a reply to message #162763] Fri, 03 March 2006 11:47 Go to previous messageGo to next message
Ausgezeichnet! ;)
Glen
>> of the box" in WTP so we wouldn't need to download a plugin for it.
>> Thanks,
>> Glen
> Kind regards,
> Daniel
Re: toString() generator available? [message #163532 is a reply to message #162763] Fri, 10 March 2006 03:51 Go to previous messageGo to next message
I am using eclipse 3.2 M5a and have not been able to find how to invoke toString() generation :/ can you tell me where it is?
regards,
Dominik
Re: toString() generator available? [message #163599 is a reply to message #163532] Fri, 10 March 2006 13:52 Go to previous messageGo to next message
Dominik G. schrieb:
> regards,
> Dominik
http://download.eclipse.org/eclipse/downloads/drops/S-3.2M5a -200602231656/eclipse-news-M5.html
The eights point shows the new generator dialog under "Source > Generate
hashCode() and equals()"
Kind regards,
Daniel
Re: toString() generator available? [message #163643 is a reply to message #163599] Sat, 11 March 2006 04:56 Go to previous messageGo to next message
Hi Daniel,
Thanks for your Reply, but i am looking for toString() generation you mentioned in your original post.
regards,
Dominik
ps.
i have used the hashCode and equals generation allready and its really helpful.
pps.
check out this thread for a discussion about the quality of the generated code: http://www.eclipsezone.com/eclipse/forums/t64643.html
Re: toString() generator available? [message #163667 is a reply to message #163643] Sat, 11 March 2006 19:22 Go to previous messageGo to next message
Dominik G. schrieb:
> Hi Daniel,
> regards,
> Dominik
> ps.
> pps.
With toString method I was a bit too fast. It seems this generator
doesn't exist in JDT UI :-(. Maybe fill a feature request against JDT UI
in bugzilla.
regards,
Daniel
Re: toString() generator available? [message #163943 is a reply to message #163667] Tue, 14 March 2006 16:22 Go to previous message
np, just wanted to make sure i did not miss someting
i decided to vote for bug26070 instead of adding a new one.
regards,
Dominik
ps. i blogged about it too: http://aviewoneclipse.blogspot.com/2006/03/i-hate-typing-ecl ipse-to-rescue.html
Previous Topic:Kudos to WTP team
Next Topic:If publishing fails, what's the best way to fix it?
Current Time: Sat Sep 06 09:48:31 EDT 2025
Powered by FUDForum. Page generated in 0.03873 seconds
