Home » Archived » BIRT » how to manipulate DataSet results
| how to manipulate DataSet results [message #162614] |
Thu, 18 May 2006 14:45  |
Originally posted by: khelenek.hotmail.com
Lets assume that using SQL the best DataSet I can come up with looks like
this (trust me):
Date | Hours | Agent Id
05/13/2006 | 2.5 hours | 1
05/13/2006 | 3.5 hours | 2
05/13/2006 | 2.5 hours | 3
05/14/2006 | 5.5 hours | 1
05/14/2006 | 7.5 hours | 3
I want to chart in a line graph:
X axis: each *unique* day,
Y axis: the total hours worked by all agents.
Basically my results needs to end up like:
Date | Total Hours
05/13/2006 | 8.5 hours |
05/14/2006 | 13 hours |
So do I need to somehow use a scripted dataset with custom java code to
create the proper DataSet from the getgo?
Or can I put script somewhere after I get the first results the transform it
and then render it with a chart?
Or can you define dataset bindings that get the data I want?
I hope that made sense... This has been driving me crazy for a few days now.
How do i manipulate my DataSet to use in a chart, to avoid creating a
monstrosity of a SQL statement?
Thank you very much,
Kris
| Re: how to manipulate DataSet results [message #162982 is a reply to message #162825] |
Fri, 19 May 2006 11:58   |
Thanks for responding,
I did try the grouping, but enabling that appears to do absolutely nothing.
The chart still displays each duplicate day on the x axis, and the
corresponding hours on the y axis. What would be my X/Y axis expression
anyway? I tried X=row["date"] and Y=row["hours"], as well as trying to use
the Total functions, but to no avail. Is there any documentation anywhere
describing this stuff? I'd be more than happy to read it.
Thanks very much,
kris
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:e4k2r9$9q6$1@utils.eclipse.org...
> Hi Kris,
> Did you try grouping on the X Axis by Date (Chart builder -> Format
> Chart->Category Series->Grouping->Enabled/DateTime/Unit=day/interval=0)?
> What happens then?
> David
> "Kris Helenek" <khelenek@hotmail.com> wrote in message
> news:e4ifcp$q8l$1@utils.eclipse.org...
like
> > this (trust me):
> > Date | Total Hours
transform
> > it
> > now.
> > Kris
| Re: how to manipulate DataSet results [message #163045 is a reply to message #162982] |
Fri, 19 May 2006 13:12   |
Did you set the type of the X Axis as "Date"?
David
news:e4kpvu$tk$1@utils.eclipse.org...
> nothing.
> use
> Thanks very much,
> kris
>> Hi Kris,
>> What happens then?
>> Thanks,
>> David
> like
>> > this (trust me):
>> > Date | Total Hours
> transform
>> > it
>> > now.
>> > Kris
| Re: how to manipulate DataSet results [message #163084 is a reply to message #163045] |
Fri, 19 May 2006 14:22   |
Hey, so I figured it out. Your first suggestion actually works great,
except I had to change the interval to be 1, not 0. I figured this out by
trying to group on agent ID (a number) instead and when I changed the
interval i realized that it is sort of a leniency parameter. Zero seems to
negate the grouping all together; so I'm not sure when setting interval to 0
is ever relevant.
But in any case, thanks for pointing me at the grouping, that solves my
problem fine.
thanks,
-kris
news:e4ku9p$v2n$1@utils.eclipse.org...
> David
> > nothing.
> > use
anywhere
> > Thanks very much,
> > kris
> >> Hi Kris,
> >> Chart->Category
> >> What happens then?
> >> Thanks,
> >> David
> > like
> >> > this (trust me):
> >> > Date | Total Hours
to
> > transform
> >> > it
days
> >> > now.
> >> > Kris
| Re: how to manipulate DataSet results [message #163116 is a reply to message #163084] |
Fri, 19 May 2006 15:39  |
Sorry Kris, you're probably right about the interval, I think we should
disable 0 for the date, it's only useful for text grouping (where actually
any other value isn't useful). Glad you had it working finally.
David
news:e4l2e3$t70$1@utils.eclipse.org...
> to
> 0
> is ever relevant.
> problem fine.
> thanks,
> -kris
>> Thanks,
>> David
>> > nothing.
>> > expression
>> > use
> anywhere
>> > Thanks very much,
>> > kris
>> >> Hi Kris,
>> >> Chart->Category
>> >> What happens then?
>> >> Thanks,
>> >> David
>> > like
>> >> > this (trust me):
>> >> > Date | Total Hours
> to
>> > transform
>> >> > it
> days
>> >> > now.
>> >> > a
>> >> > Kris
Current Time: Sun Nov 09 06:36:12 EST 2025
Powered by FUDForum. Page generated in 0.03894 seconds
