Home » Eclipse Projects » Technology Project and PMC » JDT AND CDT merging
JDT AND CDT merging [message #1254] Fri, 05 July 2002 03:30 Go to next message
I would suggest the following feature ; be able to use some features of
the CDT in the JDT. The purpose of this request is to be able to make
easily Java native Interface generation, and testing inside the JDT. It
could also useful to be able to read a .dll or .so according the OS and to
generate automatically java code with native methods. Up to now I consider
the integration of Java with the envrionment as a big lack . This feature
would simplify this integration
regards
xavier
Re: JDT AND CDT merging [message #1278 is a reply to message #1254] Fri, 05 July 2002 05:36 Go to previous messageGo to next message
I'd like to go a step further. I would like to see a migration tool that
facilitates moving from c/c++ to java. I.e., an integrated environment that
allows me too mix the two languages.
regards shmuel
"xme" <xmehaut@apri-group.com> wrote in message
news:ag3hua$7o7$1@rogue.oti.com...
> Hello,
> regards
> xavier
Re: JDT AND CDT merging [message #8492 is a reply to message #1254] Tue, 16 July 2002 09:18 Go to previous message
Xavier:
I am not sure merging JDT and CDT plug-ins would help much for JNI
development.
But I agree that there should be a joint effort between JDT and CDT teams to
make sure that, for example, debugging a Java application with JNI calls to
a C++ one ; or debugging a C++ application calling Java code using the
opposite method will be possible.
When I step from a Java method to a C++ one, I want to see the CDT
perspective,
don't you ?
Alex
Re: JDT AND CDT merging [message #566043 is a reply to message #1254] Fri, 05 July 2002 05:36 Go to previous message
regards shmuel
> Hello,
> regards
> xavier
Re: JDT AND CDT merging [message #568388 is a reply to message #1254] Tue, 16 July 2002 09:18 Go to previous message
Xavier:
development.
perspective,
don't you ?
Alex
Previous Topic:NoClassDef: AbstractSAXParser
Next Topic:educational IDE requirements
Current Time: Mon Nov 10 21:07:03 EST 2025
Powered by FUDForum. Page generated in 0.03821 seconds
