| JDT AND CDT merging [message #1254] | Fri, 05 July 2002 03:30  |  |
| Eclipse User  |  |  |  |  | Hello, I would suggest the following feature ; be able to use some features of
 the CDT in the JDT. The purpose of this request is to be able to make
 easily Java native Interface generation, and testing inside the JDT. It
 could also useful to be able to read a .dll or .so according the OS and to
 generate automatically java code with native methods. Up to now I consider
 the integration of Java with the envrionment as a big lack . This feature
 would simplify this integration
 regards
 xavier
| Re: JDT AND CDT merging [message #8492 is a reply to message #1254] | Tue, 16 July 2002 09:18  |  |
| Eclipse User  |  |  |  |  | Xavier:
 I am not sure merging JDT and CDT plug-ins would help much for JNI
 development.
 But I agree that there should be a joint effort between JDT and CDT teams to
 make sure that, for example, debugging a Java application with JNI calls to
 a C++ one ; or debugging a C++ application calling Java code using the
 opposite method will be possible.
 When I step from a Java method to a C++ one, I want to see the CDT
 perspective,
 don't you ?
 Alex
| Re: JDT AND CDT merging [message #566043 is a reply to message #1254] | Fri, 05 July 2002 05:36  |  |
| Eclipse User  |  |  |  |  | I'd like to go a step further. I would like to see a migration tool that facilitates moving from c/c++ to java. I.e., an integrated environment that
 allows me too mix the two languages.
 regards shmuel
 "xme" <xmehaut@apri-group.com> wrote in message
 news:ag3hua$7o7$1@rogue.oti.com...
 > Hello,
 > regards
 > xavier
| Re: JDT AND CDT merging [message #568388 is a reply to message #1254] | Tue, 16 July 2002 09:18  |  |
 development.
 perspective,
 don't you ?
 Alex
FUDForum. Page generated in 0.03501 seconds
