Home » Language IDEs » ServerTools (WTP) » CHKJ3000E: WAR Validation Failed: java.lang.NullPointerException
CHKJ3000E: WAR Validation Failed: java.lang.NullPointerException [message #162077] Sat, 25 February 2006 18:32 Go to next message
I'm not sure what this error is all about. I've done a google search
and only got a couple hits back. A couple were people asking this same
question on an eclipse mailing list. Neither got an answer.
I am running the latest WTP "all in one download" on a Win XP machine
with a java version "1.5.0_04".
Any ideas?
Erik
Re: CHKJ3000E: WAR Validation Failed: java.lang.NullPointerException [message #162177 is a reply to message #162077] Mon, 27 February 2006 09:29 Go to previous messageGo to next message
Ping. Anybody out there? Surely, somebody else had gotten this error
before.
I've gotten it with two different Dynamic Web Projects I'm working on.
The Problems view reports the error on the name of my project. So it
doesn't really give me a starting point to debug the problem.
Erik
Re: CHKJ3000E: WAR Validation Failed: java.lang.NullPointerException [message #162185 is a reply to message #162077] Mon, 27 February 2006 09:35 Go to previous messageGo to next message
before.
Erik
Re: CHKJ3000E: WAR Validation Failed: java.lang.NullPointerException [message #162264 is a reply to message #162185] Mon, 27 February 2006 13:29 Go to previous messageGo to next message
>> same question on an eclipse mailing list. Neither got an answer.
> before.
> Erik
Is there a stacktrace in the .log?
Re: CHKJ3000E: WAR Validation Failed: java.lang.NullPointerException [message #162280 is a reply to message #162264] Mon, 27 February 2006 14:32 Go to previous messageGo to next message
which .log? this is what i have.
Erik@WeibustLaptop ~/c/dev/apps/eclipsePlus
$ find . -name "*.log" -print
../configuration/org.eclipse.update/error_recovery.log
../configuration/org.eclipse.update/install.log
Re: CHKJ3000E: WAR Validation Failed: java.lang.NullPointerException [message #162504 is a reply to message #162077] Tue, 28 February 2006 17:16 Go to previous messageGo to next message
I had the same problem. Eclipse seems to cache xml definition files in
some plugin folder. After clearing that cache manually (deleteing all
files in there) the error went away. Although I tried many, many other
things as well (a couple of clean/rebuild, add to/ remove from server,
etc), I think the clearing of the cache folder was the trigger
More a workaround than a solution. Hope it works for you.
Re: CHKJ3000E: WAR Validation Failed: java.lang.NullPointerException [message #162566 is a reply to message #162504] Wed, 01 March 2006 02:51 Go to previous message
Originally posted by: rd.domingo.nl
This helped me solving the problem, I removed
Eclipse\plugins\org.eclipse.tomcat_4.1.30.1\webapps\ROOT\WEB -INF\web.xml
thnx,
raymond
Previous Topic:web.xml error
Next Topic:WTP 1.0.1 Flexible Project Support - How to include non Java resources from another project?
Current Time: Sun Aug 31 18:39:01 EDT 2025
Powered by FUDForum. Page generated in 0.04250 seconds
