Home » Modeling » GMF (Graphical Modeling Framework) » contained node occupies all of the space
contained node occupies all of the space [message #161681] Tue, 20 November 2007 10:59
hi, I've a container meant to hold more than an item, as I place one of
these containers in old gmf1 i can add inside many things, as the
contained items did not occupy all of the "area" of the container.
Now, porting to gmf2, as I add an item to the container, this occupies all
of its space, so no any more items can be added, resulting in a failure.
I think the interested part to edit should be MyContainerEditPart.java but
I'll appreciate every suggestion.
Note that I did not modify the models (gmfgen, ecc.. files) from the old
gmf1 (only migrated) so every setting is the same as before, "flow chart"
as well, the only thing that can be different is in the ".diagram" package.
Paolo
Previous Topic:How to replace the default CreateCommand for a Link
Next Topic:Populating the model with additional info without affecting the model file
Current Time: Tue Nov 18 16:51:36 EST 2025
Powered by FUDForum. Page generated in 0.04385 seconds
