Home » Language IDEs » ServerTools (WTP) » SSE, formatting, and XHTML
SSE, formatting, and XHTML [message #161481] Tue, 21 February 2006 18:44 Go to next message
Originally posted by: svolix.gmail.com
Howdy,
I've just downloaded WTP and am trying to learn to use it. One of my
simplest projects involves coding up a static HTML/tables/based page into
XHTML/CSS-strict.
Unfortunately, while the built-in formatter indents table tags
wonderfully, switching them all into div tags is not handled as well. I
was hoping that everything inside a pair of div tags would be indented in
order to delineate its contents, but instead, the formatter brings them
back to the home line. Worse, my manual indentations are completely
overridden by the formatter. Nested divs are unbearable to sort out.
Is there any way to change this behavior? The Preferences menu has a
handful of formatting options, but they're pretty limited in scope.
I'm using WTP 1.5M4. Thanks!
Re: SSE, formatting, and XHTML [message #161515 is a reply to message #161481] Wed, 22 February 2006 01:31 Go to previous message
No, sadly not. We (and many in community) would like to make improvements
in the formatting options.
I realize this isn't all that handy, but for some spots, you might be able to select
some limited element and format just that element. (And, dont' forget, selecting a
whole block from left column and pressing tab (or shift-tab) should shift right (or left).
Previous Topic:User Libraries
Next Topic:need help installing WTP
Current Time: Wed Nov 05 22:42:17 EST 2025
Powered by FUDForum. Page generated in 0.05655 seconds
