Home » Eclipse Projects » Eclipse Platform » How can a plugin save a project-dependend state
How can a plugin save a project-dependend state [message #161447] Tue, 25 November 2003 03:06
I have a plugin which applies some checks on java projects. For each project
you can define which checks should be enabled or disabled. I want to persist
this information. Currently I'm saving it as a project's attribute. The
problem with this solution is, that if I remove a check, the project
properties doesn't remove it and references it (at least for closed
projects). So I'm searching for a solution to save the project dependend
state in my plugin. Are there any best practices?
Thorsten
Previous Topic:Remote debugging on production system
Next Topic:Keyboard shortcut for select current word
Current Time: Sat Nov 22 22:27:38 EST 2025
Powered by FUDForum. Page generated in 0.03929 seconds
