| problem with callisto and jboss [message #161155] |
Sun, 16 July 2006 13:46  |
Originally posted by: jctown.nb.sympatico.ca
I have installed the full Jboss4.0.3 and am trying to use it with
Eclipse Callisto. I've added the server but when I try to start it, I
get the following errors
java.lang.NoClassDefFoundError: Files/jboss-4/0/3/bin////lib/endorsed
Exception in thread "main"
I checked the launch configuration and see this in Arguments
-Dprogram.name=run.bat -Djava.endorsed.dirs=C:/Program
Files/jboss-4.0.3/bin/../lib/endorsed -Xms128m -Xmx512m
Why does Eclipse think that the endorsed directory is located where it
does? I put the ejb3 jar files in the %JAVA_HOME%/lib/endorsed
directory but still not good. What am I doing wrong here?
| Re: problem with callisto and jboss [message #161163 is a reply to message #161155] |
Sun, 16 July 2006 15:46  |
I do not know if this will work, but I have had major problems with some of
my installed software becoming invisible after using Callisto.
Suggest start over with virgin Eclipse, go to Callisto, get everything you
ever want to get, and THEN install Jboss.
On 7/16/06 11:46 AM, in article e9du1a$d40$1@utils.eclipse.org, "JT"
FUDForum. Page generated in 0.08636 seconds
