Home » Eclipse Projects » GEF » Line Figure with a small circle at both end
Line Figure with a small circle at both end [message #161053] Wed, 08 December 2004 22:38 Go to next message
Originally posted by: jsk_lam.hotmail.com
Can someone show me how to make the line figure which
have a small round circle at both end? See below:
o-----------------------o
slam
Re: Line Figure with a small circle at both end [message #161069 is a reply to message #161053] Thu, 09 December 2004 04:31 Go to previous messageGo to next message
Something like this (untested!):
Polyline line = new Polyline();
Point start = new Point(50, 50);
Point end = new Point(100, 50);
line.setEndpoints(start, end);
Rectangle bounds = new Rectangle(0, 0, 10, 10);
Ellipse circle1 = new Ellipse();
start.x = start.x - (bounds.width / 2);
start.y = start.y - (bounds.height / 2);
bounds.setLocation(start);
circle1.setBounds(bounds);
Ellipse circle2 = new Ellipse();
end.x = end.x - (bounds.width / 2);
end.y = end.y - (bounds.height / 2);
bounds.setLocation(end);
circle2.setBounds(bounds);
HTH,
Igor
Re: Line Figure with a small circle at both end [message #161118 is a reply to message #161069] Thu, 09 December 2004 10:21 Go to previous messageGo to next message
You could extend ellipse and implement rotatable decoration.
"Igor Stroh" <igor@rulim.de> wrote in message
news:cp9626$fo5$1@www.eclipse.org...
> HTH,
> Igor
Re: Line Figure with a small circle at both end [message #161179 is a reply to message #161118] Fri, 10 December 2004 01:00 Go to previous message
I would be interested if anyone has done this. I ended up creating a
PolygonDecoration with eight points: it looks good enough if it is
small. An proper circle could take advantage of the fact that the
figure itself doesn't have to be rotated.
My problem is that I just haven't waded through enough of the draw2d
code to figure out how the ends of the Polyline are rendered so that I
can do what is suggested.
Barry
Previous Topic:How to be notified when layout is done
Next Topic:Can a figure be resized automatically ?
Current Time: Fri Nov 14 05:16:03 EST 2025
Powered by FUDForum. Page generated in 0.27373 seconds
