| Skyway Software Announces Skyway Builder CE [message #15130] |
Fri, 04 April 2008 10:13 |
Skyway Builder Community Edition is a set of model-based Eclipse plugins
for building and deploying rich Internet applications and Web Services.
The plugins produce standard java code using the Spring Framework and
Spring MVC.
Key Features/Notes
- RCP version or Eclipse plugin (Eclipse v 3.3 with JDK 5)
- Build and deploy full applications without writing code
- Generate standard Java code
- Use Spring Framework, including Spring MVC
- Deploy to web-only or web/EJB3 environments
- Seamlessly blend custom code into models
- Extend the modeling environment
- Automated testing (JUnits)
- Community site to support users (www.skywayperspectives.org)
For more information and to download Skyway Builder CE, please visit us.
http://www.skywayperspectives.org/portal/web/guest/downloads /overview
To participate in the active discussion, join the Skyway Community.
http://www.skywayperspectives.org/portal/web/guest/home
Thank you.
David Castro, on behalf of the Skyway Software Product Delivery Team
FUDForum. Page generated in 0.03990 seconds
