Home » Modeling » GMF (Graphical Modeling Framework) » Fill Gradient
Fill Gradient [message #160983] Fri, 16 November 2007 11:04 Go to next message
Originally posted by: martinschmidt.83.web.de
I want to add background gradient to a rectangle figure. I found some
comments in newsgroup, but i don
Re: Fill Gradient [message #160991 is a reply to message #160983] Fri, 16 November 2007 11:15 Go to previous messageGo to next message
Originally posted by: trommas.yahoo.com
Please see my thread earlier, it is a relatively simple procedure. You
override the method in the editpart's XYZFigure class. Ex:
XYZ.edit.parts.XYZEditPart -> XYZFigure.
HTH,
Tomas Zijdemans
Martin Schmidt wrote:
> comments in newsgroup, but i don´t understand it. I don´t know where to
> override the fillShape method :(
> Can somebody give an approach for a beginner?
> Regards, Martin
Re: Fill Gradient [message #161116 is a reply to message #160991] Sun, 18 November 2007 14:07 Go to previous messageGo to next message
Originally posted by: martin.tauber.t-online.de
Hi Tomas,
did you find a solution? I added the following code to the
<whatever>EditPart.java for the <whatever> class inside:
public void paintFigure(Graphics g) {
Rectangle bounds = getPrimaryFigureBounds();
Point topLeft = bounds.getTopLeft();
Point bottomRight = bounds.getBottomRight();
Pattern pattern = new Pattern(Display.getCurrent(), topLeft.x,
topLeft.y, bottomRight.x, bottomRight.y,
ColorConstants.white, ColorConstants.darkBlue);
g.setBackgroundPattern(pattern);
g.fillRectangle(bounds);
well, but what should I say ... It didn't work. I am a little bit
surpriced since the following code generates a box (whithout gradient)
as expected:
// Rectangle bounds = getPrimaryFigureBounds();
// Point topLeft = bounds.getTopLeft();
// Point bottomRight = bounds.getBottomRight();
// Pattern pattern = new Pattern(Display.getCurrent(), topLeft.x,
// topLeft.y, bottomRight.x, bottomRight.y,
// ColorConstants.white, ColorConstants.darkBlue);
// g.setBackgroundPattern(pattern);
Maybe someone could shade some light on this, why the pattern does not work.
Martin
> HTH,
> Tomas Zijdemans
>> to override the fillShape method :(
>> Regards, Martin
Re: Fill Gradient [message #161140 is a reply to message #161116] Sun, 18 November 2007 16:14 Go to previous messageGo to next message
Comments below
Martin Tauber wrote:
> Hi Tomas,
To filling scalable polygons and ellipses with gradient? No.
I am confused, are you trying to fill a rectangle? To do this I do:
public xyzFigure() {
this.setBackgroundColor(ColorConstants.orange);
this.setForegroundColor(ColorConstants.white);
this.setBorder(new LineBorder(ColorConstants.black, 1));
createContents();
* @generated NOT
protected void fillShape(Graphics graphics) {
graphics.fillGradient(getBounds(), true);
I am a little bit
> as expected:
You won't get a gradient without setting foreground and background color.
As I mentioned, I am not quite sure I understood what you meant, but I
hope this helps!
Best Regards,
Tomas Zijdemans
> Regards
> Martin
>> HTH,
>> Tomas Zijdemans
>>> Hi,
>>> Regards, Martin
Re: Fill Gradient [message #161275 is a reply to message #161140] Mon, 19 November 2007 08:00 Go to previous messageGo to next message
Hi Tomas,
(1)
I think we are not talking about exactly the same thing. My Figures in
GMF are children org.eclipse.gmf.runtime.gef.ui.figures.NodeFigure,
which does not have a method called fillShape. fillShape is a method of
Shape as far as I understand. So the method that I am using is paintFigure.
paintFigure now take org.eclipse.draw2d.Graphics as a parameter which is
the parent of ScaledGraphics. So I am confused why you are saying you
didn't manage to get a solution for scalable polygons and ellipses.
(2)
As I understood the Pattern class it takes two colors to create the
gradient. So why sould I then set the foreground and background class.
Martin
> Comments below
>> Hi Tomas,
> createContents();
> * @generated NOT
> @Override
> I am a little bit
>> as expected:
> hope this helps!
> Best Regards,
> Tomas Zijdemans
>> Regards
>> Martin
>>> You override the method in the editpart's XYZFigure class. Ex:
>>> HTH,
>>> Tomas Zijdemans
>>>> Hi,
>>>> some comments in newsgroup, but i don´t understand it. I don´t know
>>>> where to override the fillShape method :(
>>>> Regards, Martin
Re: Fill Gradient [message #161306 is a reply to message #161275] Mon, 19 November 2007 08:30 Go to previous messageGo to next message
> Hi Tomas,
> (1)
I think we are using the same class (default gmf) fillShape and
paintFigure are both methods of Shape. So far I have only tried
fillShape (works great for rectangles but nothing else) - You got
gradient working on other figures than rectangles using paintFigure?
That would be great news!
> (2)
I have little experience with the Pattern class. I thought you were
using fillShape.
Tomas Zijdemans
Re: Fill Gradient [message #161503 is a reply to message #161306] Mon, 19 November 2007 11:40 Go to previous messageGo to next message
Hi Tomas,
Hm, I'm actually traing to learn as much as possible from GMF, thats why
I am following the newsgroup intensivly. So I thought that shapes with
gradient would be a cute idea for my project ;-) Well but the bad news
is, that I havn't done it yet ....
About out discussion on org.eclipse.draw2d.Shape and
org.eclipse.gmf.runtime.gef.ui.figures.NodeFigure both implement the
IFigure interface and I think this is key. I guess you are not using
customizable figures so maybe hen the code generater just generates a
Shape object. Nevertheless NodeFigure doesn't have the fillShape method ...
Martin
>> Hi Tomas,
>> (1)
>> of Shape as far as I understand. So the method that I am using is
>> paintFigure.
>> (2)
> using fillShape.
> Tomas Zijdemans
>> Hi Tomas,
>> (1)
>> paintFigure.
>> (2)
> using fillShape.
> Tomas Zijdemans
Re: Fill Gradient [message #161536 is a reply to message #161503] Mon, 19 November 2007 16:34 Go to previous messageGo to next message
> Hi Tomas,
Ok. One of us is bound to figure it out sooner or later!
> Shape object.
I use Scalable Polygons with template points. This generates figures
which extends draw2d.Shape, this class has both methods (paint and
fill). I guess they do the same?
Reading on the GEF newsgroup, background patterns seems like the only
solution available (but even they seem have much trouble with that).
Tomas Zijdemans
>>> Hi Tomas,
>>> (1)
>>> in GMF are children
>>> org.eclipse.gmf.runtime.gef.ui.figures.NodeFigure, which does not
>>> have a method called fillShape. fillShape is a method of Shape as far
>>> (2)
>> using fillShape.
>> Regards,
>> Tomas Zijdemans
>>> Hi Tomas,
>>> (1)
>>> in GMF are children
>>> (2)
>> using fillShape.
>> Regards,
>> Tomas Zijdemans
Re: Fill Gradient [message #161620 is a reply to message #161536] Tue, 20 November 2007 02:36 Go to previous message
Hi Tomas,
if you find a solution, let me know.
Martin
>> Hi Tomas,
>> why I am following the newsgroup intensivly. So I thought that shapes
>> with gradient would be a cute idea for my project ;-) Well but the bad
>> news is, that I havn't done it yet ....
>> Shape object.
> Tomas Zijdemans
>>>> Hi Tomas,
>>>> (1)
>>>> in GMF are children
>>>> (2)
>>> using fillShape.
>>> Regards,
>>> Tomas Zijdemans
>>>> Hi Tomas,
>>>> (1)
>>>> in GMF are children
>>>> (2)
>>> using fillShape.
>>> Regards,
>>> Tomas Zijdemans
Previous Topic:Implementing a DEVS modeling plugin
Next Topic:BorderItemRectilinearRouter.
Current Time: Tue Jul 15 10:19:32 EDT 2025
Powered by FUDForum. Page generated in 0.26731 seconds
