Home » Archived » BIRT » build BIRT from eclipse
build BIRT from eclipse [message #160843] Mon, 15 May 2006 00:23 Go to next message
anyone knows how to build BIRT FROM eclipse 3.1.0
i have followed the following link
http://www.eclipse.org/birt/phoenix/build/buildInstructions. php
but i think the above tutorial is not 100% stable document.
plz help me if you build BIRT in eclipse
when i run the BuildViewer.xml i got some error message
whis is follows
Buildfile: D:\eclipse-project\org.eclipse.birt.report.viewer\BuildViewe r.xml
init:
model:
buildDependents:
[echo] start call Jar task in ../org.eclipse.birt.core
init:
compileSource:
[javac] Compiling 101 source files to D:\eclipse-project\org.eclipse.birt.core\bin
BUILD FAILED
D:\eclipse-project\org.eclipse.birt.report.viewer\BuildViewe r.xml:218: The following error occurred while executing this line:
D:\eclipse-project\org.eclipse.birt.report.model\BuildModel. xml:339: The following error occurred while executing this line:
D:\eclipse-project\org.eclipse.birt.core\BuildCore.xml:161: D:\eclipse-project\org.eclipse.birt.report.viewer\plugins not found.
Total time: 2 seconds
Re: build BIRT from eclipse [message #161114 is a reply to message #160843] Mon, 15 May 2006 14:40 Go to previous messageGo to next message
hi. i have eclipse 3.1 and works just fine. I was just following the steps
from the BIRT "How to Install" tutorial. Nothing fancy at all.
Cristian
Re: build BIRT from eclipse [message #161198 is a reply to message #160843] Mon, 15 May 2006 17:02 Go to previous messageGo to next message
Those instructions are currently written for BIRT 2.0.1.
They will be updated shortly for BIRT 2.1.
Jason
"raju" <saiful.raju@gmail.com> wrote in message
news:33206848.1147667030956.JavaMail.root@cp1.javalobby.org...
> whis is follows
> Buildfile:
> init:
> model:
> buildDependents:
> init:
> compileSource:
> BUILD FAILED
Re: build BIRT from eclipse [message #161285 is a reply to message #161198] Tue, 16 May 2006 02:24 Go to previous message
my problem not run birt in eclipse, problem is i want to build the source code of birt , but there is not necessary library for that, such as icu4j.jar not included at CVS repositary
Previous Topic:One Row Per Page
Next Topic:Weblogic - Error deploying Webviewer Example
Current Time: Thu Nov 06 14:19:17 EST 2025
Powered by FUDForum. Page generated in 0.03315 seconds
